Question about Vizio VO47L 47 in. LCD TV
My GV47 LF has gotten darker what can I do? - Vizio VO47L 47 in. LCD TV
  • brubaker63 Jul 03, 2009
    what is the cost?
    Brigadier General:
  • 8,619 Answers
Hi
First thing you can do is try leaving the TV unplugged for 30mins-2hrs; so the Tv can reset itself. If that doesn't work, then the problem is the power supply module for the screen which is also know as the Backlight inverter board. As the screen require lot of energy to power them and the power supply for the screen tends to burn out. So you need to replace the circuit board that powers the screen; then it should work again.
Please do accept the solution and revert for further assistance. Thanks Rylee
Posted on Jul 03, 2009
  • Rylee Smith
    Rylee Smith Jul 03, 2009
    It will cost you around $150-$200.
    Thanks
    Rylee
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
My printer prints fine, but how can I make it print darker. It seems to have gotten much lighter and the ink is relatively new.
There should be a button on the top that says lighter/darker, move it 2 clicks to the right for more ink to be used..... please let me know if there is anything else you need, happy to help! Guy :)
Sep 23, 2010 | HP LaserJet 3050 All-In-One Printer
Samsung 56 inch lcd tv..picture suddenly got darker not clear anymore....what can it be??
I belive this is a rear projection tv and if the picture has gotten darker.... most likely the problem will be in your TV Lamp.
Apr 30, 2010 | Samsung HL56A650 56 in. TV
We have cleaned a stick tape adesive mark of some exterior titanium tiles with white spirts but this has left a darker mark can you suggest a method to solve this problem, we are not sure weather these...
Hello. I have seen that some tiles are darker than others. Some may have had coating on them already or some may have gotten more that others. I recommend using a wax stripper and strip them all then reseal all of them at same time
Jul 08, 2009 | LG LFX25960 Titanium Bottom Freezer French...
Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Screen Brightness
Your ballast may not be up to 100% of its rated capabilities, thats often the cause when the brightness level gets to unwatchable levels. You may need to troubleshoot the ballast voltages a defective ballast can usually cause a lamp to loose about 60 % of its brightness levels. The other possibility could be the DLP mirrors need polishing but that is something better left to a repair shop as the DLP mirrors are sensitive
May 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Vizio VO47L 47 in. LCD TV Logo
29 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
