Where are the manual channel buttons? My remote is "MIA" and I find only the on/off button and the volume buttons. No channel button.
Assumming your remote has a keypad with a bunch of numbers 1,2,3, etc those are the channels you press the combination of the channel number you want and press enter...sscrolling up and down thru the channels is probablymore what you want, and that should be located by a set of signs wghich has horizontal or vertical arrows right nex to each other...
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
SOURCE: Volume go up to MAX, power button does not work
what is a tact switch and can i change it myself?
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
SOURCE: Toshiba 32" TV volume and channel buttons turn it on and off
You could try a universal remote
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
