60 mitsubishi had convergence problem ic were wram changed stk 4275 picture was good for 1-2 mins and then went back to original problem
  • 2,071 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem you have is the faulty convergence STK chips IC you better replace this IC. I have a picture guide an a testimony how they solve the convergence problem;
Just click below for picture guide a do-it-yourself guide;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
or
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
or
http://www.repairfaq.org/sam/tvfaq.htm#tvtvrep
Just click below for electronics store online;
Partstore.com.
Mitsubishi- Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
http://www.freelists.org/archives/techassist/
http://www.eserviceinfo.com
Regards,
VOTIT
Posted on Jul 03, 2009
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Before Thanksgiving the color went 3-D and the picture waved. I ordered a convergence kit but the problem stopped, so we didin't install it. It started back up yesterday & this morning the video went...
Yes,the convergence problems it the cause,but also now could be have addtion some other problems too it.But change the 2 STK convergence ICS and all the resistors to it, fix the convergence board first see what happen.
Jan 01, 2011 | Mitsubishi TS-5545 55" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Thanks
Oct 11, 2008 | Televison & Video
Convergence gets very bad the longer the TV is on.
The convergence amps will have number on them starting with STK replacing thes may do the trick or you may just have a poor solder connection at these ic's try soldering them first if no go then replace them look around on the convergence amp cba on the bottom for obviuos bad connections small ring crack are hard to see these ic's work hard that is one reason for their large heat sinks running the set and turning it on and off may have induced fine ring cracks. i amsorry I dont have a schmatic for this set but the ic's do have their (generic) part number wrote on them as do most all transistors and diodes and ic's
Aug 22, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
JVC AV-48WP30 will not give a picture
Replace the convergence IC`s again using original Sanyo chips (STK 392-110 or STK 392-180). Make sure to use plenty of heat sink compound. Coat the entire back side of the chips. Also look to see if any of the low ohm resistors are burned. A shorted chip will cause the thumping sound and the set will shutdown. I am guessing that you used generic IC`s as a replacement. They are cheap and the leggs fall off when you apply too much heat during soldering. Dont wory about the CRT driver or the deflection board, they are probably fine.
Dec 12, 2007 | JVC AV-48WP30 48" Rear Projection...
No picture have sound
sounds like your IC's took a dive again. Did you change them or a shop? You have to also make sure that when you change the IC's that you put plenty of heat sink compound on the back of the IC's and do not use the cheapy IC's that you can get for 20 bucks or less as I have found they do not last. This convergence board should be available as a complete board. Good Luck
Mar 29, 2007 | Zenith IQZ60Z97D 60 in. Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
