Question about Bose Lifestyle 25 System
Hello, I need to manually eject CD magazine from Bose 25 system. The disk inside the amagazine does not work, and ther error E01 appears. At the buttom of the device I see the label "Manually eject CD Magazine:" and several holes around this label but I coud not find any indication how to use it Thanks
  • 2,418 Answers
Most of the time you need a paper clip, med sized straighten it out unplug the player and push the pin in a hole about the size of the clip. you will feel a resistance and push thru it. That should open the door.
Posted on Jul 03, 2009
Eject cd magazine
At downside of the music center, right corner, there is a "manual eject system" indicator. just push inside slide to upward with a thin screw driver and your magazine will be ejected..
Jul 03, 2013 | Bose Lifestyle 25 System
Bose
Does the magazine eject?If yes,the optical lens or mechanism is bad.If no,the power board is bad.
Mar 30, 2013 | Bose Lifestyle 25 System
I can not eject a disc from the disc player. I've heard this is a common problem. Thanks. Curt Pasawicz
Hi curt730,
You're right, this is a known issue for years with Bose Lifestyle. You may try these steps to resolve the issue:
Note: You will need a flashlight and a small screwdriver.
1. First, disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Then, using the flashlight, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. The moment you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Finally using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in the player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Hope this helps.
Thank you for using FixYa.
Jun 08, 2011 | Bose Lifestyle 28 System
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Bose Lifestyle 30 6-cd changer magazine manual release?
    hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
    Jul 29, 2007 | Bose Lifestyle 30 System
    Bose Lifestyle 25 System Logo
    609 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
