Question about Home
We have an in-sinkerator and want to replace our old sink with an Oliveri double sink such as the MO 753 or PE353 will it fit? Cheers tony
    President:
  • 3,433 Answers
The holes a standard among all sinks. Kitchen sinks, that is.
Posted on Jul 03, 2009
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
The hose head keeps falling away from the unit. It should stay pushed in
Has no hose weight or not heavy enough weight on hose under sink. either buy a weight and install on hose about 18" from the bottom of sink. or you can use a 3 ounce fishing sinker with bread tie and tie it around hose aprroximately 18" from bottom of sink. It needs the weight to keep the faucet head in.
Aug 31, 2011 | Grohe Plumbing
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
Denzel 10 of his first 15 shots in a basketball free-throw contest.his success rate stays about the same for his next 100 free throws.write and solve a proportion to answer each part.round to the nearest...
He sinks 10 of 15 shots. 10/15 = 2/3 = 0.66, or 66% success rate.
66% of next 100 throws = 66 sinkers.
66% of 80 throws = 0.66*80 = 52.8 sinkers. Round to 53 per instructions.
What team does he play for?
Feb 04, 2010 | SuperTutor Homeworkhelp.Com Super Tutor...
How do i install them?
First do a dry fit to make sure it fits in hole properly then put a bead of clear silicone on the countertop around the cut out edge lay sink in hloe and install the mounting clips do not overtighten mounting clips they only need to be snug clean excess silicone with a rag.I suggest installing faucet and basket strainers first on sink before installing makes job easier
Nov 11, 2009 | Neptune Ace Good Series Double Bowl Sink
Hi there, Ive got oliveri double bowl n one of the plug has broken. what should i do?
You can buy replacement stoppers at most hardware stores bring old one to match up
Aug 16, 2009 | Home
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Cement sink drain repair
Yes you can still get those basket strainers and you can replumb with plastic pipe. Make sure when you go to the store to get the extra long strainers made for thick sinks, the fitting on the bottom should be made to accept plastic pipe. You may also need a "mission band" or "fernco coupling" to attach the plastic to metal pipe after replacing everything under the sink.
Mar 23, 2009 | Plumbing
Replacement kitchen sink sprayer will not fit
It might be easier just to take the sprayer back and get the corrct brand to fit your faucet. The other option is to takke the two missmatched pieces to the hardwareor plumbing supply house and let them match us the transition fitting.
Jan 28, 2009 | Home
Pp1020 harddrive
Hi doug160451,
Could you please post the specifications of your laptop, but if your laptop originally came with a 5 Gb Hard Drive then chances are it would be an old laptop and you would do better upgrading to a new laptop than go through the problems associated with upgrading only your hard drive.
Cheers
CptHaddock
Nov 07, 2008 | Compaq Presario Notebook
Home Logo
78 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
