Question about Intertherm Heating & Cooling
Central air has a lack of pressure and is not cooling the entire house... what can we do?
  • littlamsterd Jul 03, 2009
    Well it is in a mobile home and we have lived here for about a year... The mobile home is 9 years old.This happened to us once before and all we had to do was turn the unit off for a day and then it seemed to kick back on. We tried that again today but it doesn't seem to have enough pressure in the living room and it isn't as cold as it was before.
  • 35 Answers
Dont know what your location is or how old the house is but if you have flexible ducting in the attic you can check to see if the return line from the filter is either kinked or collapsed, If the A/C company did not install the proper size return duct the fan in the a/c unit can **** on the duct hard enough to collapse it.
Posted on Jul 03, 2009
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
Can anybody tell me how to change fuel injectors on 1989 audi 200 quattro?
first relief fuel pressure before disconnecting fuel lines remove fuel pump fuse or relay start engine let it idle until stall out lack fuel fuel now fuel pressure is reliefed. you have to remove top upper air cleaner housing, you have to remove whole entire air cleaning system because the fuel lines with fuel injectors is under the air cleaner filament you have to remove entire fuel line with fuel injector in order to replace fuel injector.
Nov 21, 2011 | Audi Cars & Trucks
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
I have the York Outdoor Split System Air Conditioner- Model # h4de024S06A, Installed in my home on june 12, 2004. We had no problems at all until last night when we noticed that the Furnace of the Fan is...
I think you may have 2 problems. Thje outdoor fan not coming on would cause the compressor to either go out on high discharge pressure or internal overload. Either the fan is bad or the capacitor is bad or both, which can be replaced.
The second problem is either the unit froze up on you and for the short time that it will cool before it quits. You may want to make sure you cool speed for your indoor unit is set to hi cool speed which is usually black
Jul 06, 2010 | Heating & Cooling
Central A/C takes a long time to cool house
The system should be either R-22 or R-410A
You need to go outside and feel the suction line (the big line) with the unit running, after the house is cooled down, it should be cold and sweating,if the humidity is not to low, if it is your unit is probably ok. High Effeciency units
usually have a higher suction pressure and temperature and can run longer, if it's sized right. After the house is pulled down to temperature and starts cycling, it should come on and go off about 3 times per hour. The longer the unit runs the more dehumidification it should do.
Aug 22, 2009 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
My central air conditioner is putting out cool(weak) air, not cold air
Number one problem is lack of air flow usually due to dirty filter or dirty evaporarator or condensor. Clean and service both , first before anything else.
Jun 19, 2009 | Ruud UBHC Air Conditioner
Air conditioner does not work, blows air strong but not cool air
sounds like a piece of junk to me....bring it by the house and I will get rid of it for ya.....just tryin'...If the A/C was working last season but not now...it is most likely a failed pressure switch in the A/C system or a lack of freon...OR...the compressor switch has failed preventing the compressor from engaging.
let me know what you find, or just bring it by the house...
clarkco
Apr 29, 2009 | Heating & Cooling
Unbalanced cooling or heating
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
Feb 23, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
