Question about 2wire HomePortal 100 Network Adapter
D-link dwa-130 wirless
Having trouble with my d-link dwa-130 not getting good connection
Re: d-link dwa-130 wirless
Same problem here ... I installed the beta driver 1.2 and seems to help.
Posted on Dec 15, 2007
    Problem Solver:
  • 6 Answers
What kind of poblem ....
is it totally not working or it is working slowly
what ur trying to say...
Posted on Nov 10, 2007
    Problem Solver:
  • 5 Answers
I installed the beta drivers and it seems to be working very well now.
Hope the same works for all of you.
Posted on Jan 28, 2008
  • 226 Answers
The Dlink DWA-130 is an antenna designed to pick up long range signals from gateway sources. I use it as my primary internet access here in Korea and it does the job it is supposed to. It was not designed to be primarily a short range device, however a person can adjust the power settings in the device driver under Device Manager. The problems people are mentioning about audio cutting off is not due to anything other then the operating system ( not the device driver for DWA-130 ) not responding well to new sources. I have seen all the issues mentioned so far. It works so well I am thinking about buying another one to test co-phasing them... That might be a while yet tho. What I am wondering is, did anyone else besides myself notice the lack of driver installation from the driver CD into Vista. I've had my DWA-130 for about a year now and it is exposed to winter temps and summer rain covered only by a plastic garbage bad for protection. Still working great and I use it constantly. I have seen 400 kB/s using this device ( yes I wrote that correctly ) which is 4 times the speed of my old wired Motorola cable modem.
Posted on May 09, 2008
0 characters
3 Points
When i put my d-link dwa-130usb adaptor in my computer it says i need drivers to install the adaptor where do i go so i can download that driver
> Where do I go ....
Enter 'DWA-130' into the input-box just below "Product Support & Downloads",
to find downloads for your D-Link device.
Jul 19, 2011 | D-Link DWA-130 Pre-802.11n Wireless...
When I try connecting to my router (Verizon FIOS UltraLine Series3 Model 9100 EM) with the Dlink DWA-130 it says "connecting and key wait" I tried resetting my router and reinstalling the driver and...
I'm having this same problem. Will it connect to any other network? I've tried going into the settings on the network and changing the channel and a bunch of other settings. I've tried 2 different revisions of this same product. I'm starting to think it must be something in Window's that's interfering with my wireless card. I'll keep you posted if I figure anything out.
Aug 20, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
Dlink DWA 130 adpater problem
裝左個dwa-130usb, 但用usb 上唔到網, 個手指冇燈...係唔係壞左,我剛拆合用
Mar 17, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
I need an install disk for my usb wireless adapter. I lost my disk.
OK... Just download the driver/software revision matching your USB adapter (have a look on it's sticker. If no revision is noted, then it's simply DWA-130!):
I assumed you're using a Windows OS...
Mar 13, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
It keeps saying that i need a keyword but i don't have one.what do i do?
The "Keyword" is just a "Password" you will have to ask the persons network you are trying to connect to for it.
Feb 14, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
DWA-130 work on WRT54G router?
Yes, the WRT54G router will support all 802.1 complaint devices, including the DWA-130 wireless n.  You will however not achieve 'n' speeds, only the fastest speed supported by the router which is 54G.
Nov 12, 2008 | SMC EZ Connect Turbo SMC2435W 802.11b...
it happens to me also, always cutting off the signal, i just bought new one other brand and it works fine
Jan 27, 2008 | Network & Wireless Adapters
DWA-130 and PC running Vista
did you install a vista driver ?
Dec 19, 2007 | Network & Wireless Adapters
Network & Wireless Adapters Logo
3,027 people viewed this question
Top 2wire Network & Wireless Adapters Experts
Martin Murray
 C. Dante
C. Dante
Are you a 2wire Network and Wireless Adapter Expert? Answer questions, earn points and help others
