Question about Daewoo L700C 17" Flat Panel LCD Monitor
It dosen´t turn on
Hi, The problem that I have is that the way to switch is broken, I put a patch betwen the switch and another component but the problem is the same. Coul you want tell me , what components that I have to check please?
Tulia Castillo
The problem is in Daewoo L700C
    Problem Solver:
  • 5 Answers
You mention that a switch is broken? I am assuming that you mean the power switch for the monitor? If so, then you can probably get the manufacturer and model, look it up on the web and order a new knob or switch from manufacturer. If this is not an option, then you will probably have to take the monitor apart to see what part of your substitute button is not touching, b/c what a button does it activate a special area on a circuit board that connects or disconnects power to its specificed area (where the button is sitting)
Posted on Nov 25, 2007
Water from back of engin betwen bell housing &engin
Hi William:
3 possible sources I can throw at you:
1) Broken heater hose (not likely but possible.
2) Bad head gasket - use mirror to try to see source between head and block
3) Bad frost plug - Use mirror to try to see frost plug location at back of block.
Hope it's the heater hose. That's easiest to repair.
Sep 08, 2015 | Cars & Trucks
New fuel pump worked now dosen't 95 accliam
Check the condition of the fuel pump relay first and the condition of the wiring in both connectors inside and outside of tank second. Check condition of the ground wire return where it attaches to body- it may be broken or corroded. Inside of the tank as well. Also check to see if you have 12 volts at the pump- if not, check fuse and other wiring for damage.
Also check to make sure the oil pressure switch is intact and functioning correctly.
Oct 06, 2012 | 1995 Plymouth Acclaim
I have latitude E6400,th antenna status light (top of keyboard in left) dosen work, anyone can help me?
#1 ensure the wireless switch on the right side of the chassis is in the forward (On) position (I accidentally turn my wireless off about once a month putting the system in my carry bag.)
#2 if no change reset BIOS defaults
#3 Fn + F2
Jun 30, 2011 | Dell Latitude E6400 Laptop Computer PC...
Put torque converter in tranny and wont turn ? is the tanny bad or is the torque converter bad.
make sure you hear two tumps or steps and you cant put your fingers betwen converter and trans case. if all of this is Ok, then your oil pump is locked or broken, you wiil need a rebuilder to fix ro replace it.
Mar 27, 2011 | 1996 Toyota Camry
My windows /none of them will go up or down. replaced switch/worked a half day and quit again
might be a broken wire in the loom betwen the door and the pillar, either that or i would recommend checking the fuse, ive seen it happen before on the mpv's both a fuse and a worn out wire.
Jul 31, 2010 | 2001 Mazda MPV
My Sony Bravia's screen is showing images in red and black only. By playing with the input sockets at the back (pulling out the leads and reinserting) it was temporarily fixed the problem but, now it seems...
If you are using Component Input (green/blue/red inputs) with component patch cords, try using other input jacks ( Video In (yellow) or Cable/RF In). If the color is good, then replace your Component patch cord, the green one is broken.
Aug 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Daewoo L700C 17" Flat Panel LCD Monitor Logo
81 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
