Question about Kodak EasyShare CX4200 Digital Camera
I have a Kodak cx4200 digital camera that won't turn on. It hasn't been used for at least six months and I discovered that it had wrong batteries in it. Now it seems to be dead. Help!
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Aug 16, 2009
    This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the
    camera. If charging/replacing the batteries doesn't clear the problem, remove the batteries and wipe the terminals with a soft cloth
    (heavy corrosion may require a fine wire brush, steel wool, or
    sandpaper). Remove any residue left in the camera by the cleaning.
    Clean the terminals on the batteries in the same manner, and then
    replace them in the camera. This cures most problems, but if it
    doesn't work for you, check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/r...
    It uses a simple Q&A format to diagnose problems and propose solutions.
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
Kodak c340 won't turn on
Hello Carol, Are these batteries new and name brand ? It sure sounds like low battery power, Those cheap batteries found in some stores do not have the energy to boot a camera even when new out of the package. The camera has a very high demand to start up. I own several cameras that will not turn on with brand new cheap batteries.
Best Regards, Russell
Oct 28, 2012 | Kodak EasyShare C340 Digital Camera
I have just got a second hand cx4200 camera i have put in nomal batteries the light goes straight from green to red then switches off do i need kodak batteries
You can use any "AA" batteries, just make sure to use a fresh set.
Other options:
optional camera dock with Ni-MH rechargeable battery pack (in-camera charging); 2AA lithium or Ni-MH batteries or 1 CRV3 lithium battery, 3 volt adapter
Aug 19, 2012 | Kodak EasyShare CX4200 Digital Camera
My Kodak EasyShare M320 Digital Camera won't turn on despite it having full battery; I cleared the memory and that hasn't helped. When I press the on/off button, the camera looks like it's...
Check the contacts for the battery. They may be rusted / making poor contact. Did you leave a leaky battery in there for some time?
If you can get an Emory board or small file in there it might help to clean up the contacts. If clean, try bending the clips up to make a stronger contact with the battery.
Oct 25, 2017 | Kodak EasyShare M320 Digital Camera
I have an easyshare cx4200 camera. I no longer have the software. It was in my laptop but now is gone. I use this camera at work to take pictures of cars to post. And now I can't. I need the software and...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free program Picasa ( http://picasa.google.com ).
Feb 19, 2011 | Kodak EasyShare CX4200 Digital Camera
Battery Door
remove two small phillips head screws next to battery compartment,,this will allow you to raise the camera case enough to insert the tabs from the new battery door cover,replace the screws,,,i just replaced mine not to difficult
Jul 15, 2008 | Kodak EasyShare CX4200 Digital Camera
Kodak digital camera
Camera will not charge through USB interface, only DC input jack or camera dock.
Jun 13, 2008 | Kodak EasyShare M853 Digital Camera
Kodak EasyShare CX4200 Digital Camera Logo
82 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
