Question about JVC Audio Players & Recorders
Disc stuck in tray, will not open. JVC MX-C33
SOURCE: jvc model mx-c33 home stereo
I moved it to the garage, placed it on top of refrigerator, reset time, stations. I didnt play a cd right away. When I did, one played fine and that was it. No is wasent dropped, but I wonder if putting on the metal refrigerator somehow misaligned the laser to read cd's. thanks for your interest, Rick
[I must add though, when I brought it back into the house, it picked up and played a cd. I then went to play one of the other 5 discs and the same problem occured.
Posted on Feb 10, 2008
SOURCE: cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Posted on Mar 09, 2008
  • 6 Answers
SOURCE: Disc tray stuck closed
Thanks FYI it ALSO works on stuck XBOX (Black Original) systems!
Posted on Aug 13, 2008
SOURCE: how to unlock the disc
try while playing a disc, Stop button(Beep On/Off) + disc Eject, Hope it works.
Posted on Aug 30, 2008
SOURCE: mx-d402t jvc cd player - trays will not open
Just got one of these at the dump. Two problems quickly jumped out at me:
1. As mentioned above, the CD trays stuttered and clattered but would not open.
2. Volume control is unable to be reduced from the highest level (50).
CD tray table was an easy fix.
After removing the 8 cover screws (6 on the back and 2 on the sides) and the 6 tray mounting screws (two through the back and one in each corner) I unplugged the only electrical connector - it is a simple push in pull out type. Note the way it plugs in before pulling out - it doesn't matter which end which you unplug. I set the entire changing assembly aside (outside the tower) on a speaker - just for height because the cable is fairly short. Then hooked the electrical strip back up and turned the power on to the main unit. After setting the controls to CD and pushing the eject button for tray #1 it only took a gentle nudge of the linkage to allow the entire stack to free up. Cycled through the trays several times and each slip in and out as designed.
The next step is not for the faint of heart. Since something (in this case just some cat hair and normal 10 years of dust) was causing the trays to stick it was decided that the entire unit should be thoroughly cleaned. With most electronic devices as long as there is no power on the component it is perfectly okay to wash the entire unit with hot (really hot) water from your kitchen sink. A soft tooth brush and some liquid detergent help the process. After a good long wash and rinse, gently shake as much excess water from the piece and find a supply of warm flowing air. Set the component in front of the air supply and allow it to dry for a looong looong time. 3-4 hours is good.
Hook it back up, cycle the trays and observe the function, paying special attention to where the moving parts make contact. Then shut it down (or not depending on your confidence in your hands) and apply some WD-40 to a q-tip. Using the swab apply a small (the key word is small - you do not want oil based liquids to get anywhere near the CD reading LED) amount of lubricant to the previously observed bearing points. This procedure is best accomplished as the linkages are moving throughout their entire stroke but be careful to not catch the swab in the moving parts.
Now (while I wait for my C changer to dry out), I will trouble shoot the volume problem. If it is something that can be fixed, I will update this post. Please don't assume that just because something has some years on it that one should "expect" it to fail. Oftentimes it just needssome TLC.
Posted on Nov 24, 2008
My jvc mx c33 will not play cd's that I burn, plays store bought ones fine. I am using Roxio NXT Pro to make my cd's on to a .cda format. The jvc mx c33 doesn't recognize the disk, just says there is
Are you closing the disc? If so are you using CRD or CRDW. If you are using CDRW it will not burn in the proper output format. If you use CDR only it should. Also try recording at a slower speed. It has helped me in the past to do so.
A great program to try is CDBurnerXP, and it's free. After you record it then put it back in and run it again, but this time just select "Disc" then from the drop down menu Disc Information [CTRL+I] and read what format you ended up with. Remove that and check a store bought disc and compare.
CDBurnerXP Free CD and DVD burning software
Dec 03, 2014 | JVC Audio Players & Recorders
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
I just purchased a used JVC MX-C33 stereo and the FM radio is ot working. Do I need to have apecial antenna or other gadget to get the radio to work? DO not have the manual. Thanks
I have a used JVC MX-C33 and put the cartridge in with only one cd and only one tray in the cartridge. Now it wont eject nor will the single slot open. Any suggestions on how to open it? Thanks, Monte
Apr 28, 2010 | Audio Players & Recorders
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
JVC MX-C33 Tape Drive Problem
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
Jvc model mx-c33 home stereo
Did this problem start as soon as you moved it or did it take a couple of weeks? also did it get dropped during the move?
Feb 05, 2008 | Audio Players & Recorders
98 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
