Question about Sony Playstation 3 (PS3) Console
PS3 screen starts changing colors and then turns black or no sig
I thought it was the TV going crazy but seems its the ps3, it goes like crazy on the colors goes from a normal screen to a very red one then goes all the way to a greenish one then after a whule it starts to fade to black like if it wasnt sending any signal as the tv displays the message "serching for component signal", soud is out too...then after a few seconds the imagen and sound comes back, i'm getting worried not sure if it is overheating or its related to the cables which i dont think as the sound is also affected...any idea?
SOURCE: During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Posted on Mar 11, 2008
  • 31 Answers
SOURCE: sound but no picture on PS3 using AV3/4
if it's happening with your ps2 and your ps3 on teh same tv, try it on a different tv. if you're getting sound but no picture, tehn it's something with your cables or your tv. restting the display setting should get your picture back up. make sure the system is in standby and then hold down teh power button. it will turn green and beep, then flash green and beep again. it should brng up a picture. if not, check your component cables, especailly if it works with the original cables.
Posted on May 20, 2009
  • 31 Answers
SOURCE: ps3 is messing with my tv signal
it's usually a grounding issue with yoru cable connection. disconnect your coaxial cable from your tv and you'll lose your humming and lines.
  • 5 Answers
SOURCE: Ive had my PS3 hooked up using HDMI for years now
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Posted on Jun 09, 2009
  • 57 Answers
SOURCE: I can't get the right colors on the TV when i
It is likely that you have two of the cables reversed. Probably the green and blue cables.
Posted on Sep 22, 2009
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
When ever i try to play ps3 games on the mitsubishi hdtv 1080, the screen cuts to black with green hatchmarks. The PS3 home screen displays but as soon as i enter the game mode the screen goes black
Good day!
That is usually happens when the TV is not compatible to the PS3 because the graphics of the PS3 is very resolution.
The qualification standards of that TV is not reaching the higher resolution of PS3 even your TV is HDTV.
Thank you very much for using fixYa.
May 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS...
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Screen goes black
sounds like you're using an HDMI cable, and the cable is broken. That's exactly what happens when HDMI cables break, a few of those 0s and 1s don't make it to the TV every once and a while, and the TV goes black and the audio dies.
or
go to system update and choose online update. an optional ps3 firmware 3.01 fixes this issue
also, I had a similar situation a while back. Anytime I loaded any disk (game or movie) it would just go black and freeze. I had to do a system reset (where it reloads everything and you lose your data). You can back everything up before that and restore it once you are done. It has worked fine for nearly a year since then.
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
My ps3 screen goes black when i start playing games
try changing the resolution settings on the ps3 itself to match your tv because if the tv cant handle 1080p then dont set it to it, going into a game changes the resolution to mach the games rated one
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
The other day my ps3 was working great and today i went to use it and all that i have is a black screen. Know i have it hooked up with a hdmi cable and the tv does recognize it because when i turn on the...
It may have the changed somehow, try turning off your ps3, wait 10 secs, turn the ps3 back on and do not release the power button until you hear the beeps, it should reset your display.
Aug 02, 2009 | Video Game Consoles & Games
Can't play PS3 on LG 42LC7D tv
use hdmi cable from ps3 to rear of tv (you should have hdmi 1 & hdmi 2)then ppress input on remote until you get hdmi 1 or 2 on screen walaa
Dec 20, 2008 | LG 42LC7D-UB Television
Black screen on ps3
What tv you have and how you sony is conected with tv via hdmi,scart or video out
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Games in both B&W and color
Check your settings on the tv and the ps3.. I noticed on my assasins creed I needed to change the settings on the ps3 bc my screen was almost all black! Try it and let me know!
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
487 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
