Question about NetGear RangeMax NEXT WNR834B Wireless Router
Setup secure connection with wnr834b router - NetGear RangeMax NEXT WNR834B Wireless Router
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 03, 2009
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS).
You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network.
Manual: http://documentation.netgear.com/wnr834b/enu/202-10171-01/pdfs/FullManual.pdf
Jun 24, 2014 | Arris SURFboard SBG900 Wireless Router...
Need netgear security key
Connect the computer to the router.
Check the IP address of the router.
Open the setup page and you will find the network key.
See how to find network key
Mar 31, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
I don,t have a password or username to setup my netgear rangemax wireless n wnr834b
well if you forgot the username and password then reset the router for 20-30 secs pushing the reset button. powercycle the router for 10 secs. then open the router page>
-- http://192.168.1.1 or http://www.routerlogin.com or http://10.0.0.1
-- username and password is " admin" and "password"
-- Left side click on Setup Wizard
-- Apply basic settings
-- go to wireless settings
-- change ur wireless settings according to ur need
-- and apply all the settings.
and try to connect all the wireless computers
Apr 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless Security
enable security on router
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. define your SSID(network name) under security option select WPA then typed your security in the passphresh then click on apply
6. than try to reconnect again again from your wireless device
regards
prakash
Jan 17, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I have forgot my wireless security password ho do i retrive it
I assume you mean the wireless encryption key.
The key is accessed by opening a browser and typing in the configuration URL IP address.
To setup the encryption key and to secure your wireless router, please - click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 29, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Please send by email directions to setup wireless router (WNR834B)
You can find the user manual for your router here:
http://documentation.netgear.com/wnr834b/enu/202-10171-01/TOC.html
Oct 25, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
No wireless
try to chage the type of security in u r router ...that would fix
Jan 08, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Cannot connect wireless device
If you have the correct wireless security and the laptop wont connect wirelessly, the best thing that you can do here is to access the router setup page and change some wireless settings on the router like the wireless channel , I advice you set the wireless channel to 11 then after that try to connect your laptop again to the wireless network and by the way change also the SSID or wireless network name of the router....
Nov 04, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Problems with my new WNR834B
try to customize your wireless settings. change the wireless name/ssid to something else and change the wireless channel as well. verify also if there's a wireless security enabled, if it has you need to use the correct wireless security/network key when connecting your laptop wirelessly. you can go to the router's setup page to verify your wireless settings by typing the ip address of your router to the address bar of your web browser, http://192.168.1.1 (note: by default the ip address of the router is 192.168.1.1 unless you have changed it to something else. the default username is "admin" and the default password is "password")
hope this'll help you
ciao!
Aug 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
How to install if i don't have the installation cd of the router?
Here is a link to the setup manual. If you follow that step by step it is a piece of cake. If you still need help do not hesitate to ask and I will then walk you through it.
http://static.tigerdirect.com/pdf/netgear-WNR834B-manual.pdf
enjoy,
Lee
Jun 12, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
157 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
