Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
It sounds like a bowling ball rolling around inside the fridge.
Refrige. works and freezer works its just the occasional thumping/pounding noise? Can it be repaired? thank you!
    Sergeant:
  • 163 Answers
Sounds like maybe one of the mounts for the compressor might be bad. The compressor is around the size of a bowling ball and does need the vibration dampened to stop noises like that.
Posted on Jul 03, 2009
  • jennie55416 Jul 27, 2011
    What if the rolling ball sound is coming from INSIDE the compressor? I have an Embraco 115v 60Hz and when I moved the refrigerator, there was a clunking sound. I investigated and there is the sound of a shot-put ball rolling around inside the compressor. The compressor itself is firmly mounted.... Any ideas? Or is this the situation you were referring to?
Rear noise at high speeds
Is it more like a "thump thump thump" sound? If so, it's likely your wheel bearings.
Nov 18, 2013 | Cars & Trucks
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser doesnt work, ice dispenser works fine
1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)
Jul 19, 2009 | GE GSH25JSSS
Freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
Apr 25, 2009 | Refrigerators
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
Refrigerators Logo
282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
