Question about Spirit Esprit ET4 Treadmill
Jazfit treadmill wont work
Just bought a jazfit treadmill txo . it worked fine for about 40 minutes. then i pulled off the safty key to stop it and about 5 minutes later smoke started pouring out and it smelt of electric burning....now it wont work at all. not even the dispay lights...any ideas?
  • Lee Doran
    Lee Doran Oct 29, 2012
    The same thing has happened to our jazfit t50 treadmill. Any suggestions?
  • Lee Doran
    The control board transformer went bang? Is it worth repairing or replacing?
  • 37 Answers
Just bought one second hand. Same problem. Worked for a while finally then smoke and it shut down. Open the panel at the bottom after undoing the sides and check the on/off switch. ENSURE THE PLUG IS OUT AND TURNED OFF BEFORE DOING THIS! Mine burnt out as it was not of a high rating, and replaced it with a higher one from Jaycar.
Posted on Jan 20, 2014
  • John Rumming Jan 20, 2014
    By the way, has anyone got the manual for the Jazfit E2?
  • 33 Answers
Hai, please check control board transformer output
Posted on Oct 01, 2009
I have a Jazfit 5333 treadmill - the speed and time are not working - led is fine but does not show time or speed just random numbers flash...how do I fix this??
Sounds llike you may have problem with your speed control module which will also be linked to yr time display . Call a treadmill tech for quote & availability of parts cost labour & service
Mar 02, 2015 | Exercise & Fitness
What is the safty key
the SAFETY key attaches to the console of the treadmill usually by a magnet and is linked to the users clothing so if they fall they pull the safety key off and the treadmill automatically stops. The treadmill will not work without the safety key in place
Aug 03, 2014 | Nordic Track Nordictrack A2350 Treadmill...
Jazfit top 49 treadmill
Are you sure its E S and not E 5
Dec 16, 2013 | Exercise & Fitness
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Jazfit txo
see the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Oct 18, 2013 | Icon Epic T60 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Hi i have a jazfit-86 treadmill & you turn it on everything works how it should but the belt wont rotate do you have any ideas on how to fix this?
I have the same problem. I pulled it apart and found the spings on the cabon brushes for the motor had broken (they are found in what looks like fuse holders on the motor itself) I am trying to find out the manufacturer so I can order new brushes.
Aug 30, 2010 | Sport & Outdoor - Others
Spirit Esprit ET4 Treadmill Logo
748 people viewed this question
Top Spirit Exercise & Fitness Experts
Mister G
Mister G
Level 1 Expert
Richard Warren
Richard Warren
JonSnell Electronic
JonSnell Electronic
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
