Question about Samsung RB2155 Bottom Freezer Refrigerator
Frige freezing solid
We had the same problem this year and the vents where clogged with ice, We unplugged and cleaned the entire frige and made sure there was no more ice in vents. We continued to have problem, So we would unplug frige at night and replug in morning, Than it appreared that problem stopped. The frige worked good for about a week, and now it is not keeping the frige or the freezer cold enough. The temp is 60 for frig and the freezed at 20. We bought the frige 2 years ago and have used it only about a year. We did not take the warrenty program and we can not afford a new frige. We are thinking of buying the tempature sensor and installing that. The interactive control the numbers do not display fully and did not when we got the frige, but were busy fixing condemned house and did not do anything about it.
  • 4,070 Answers
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 03, 2009
Frige not cooling on bottom freezer frige
Check the air vents, from the freezer to fridge. Air travels through those vents. Sometimes, products get shoved under the vents, preventing air flow. It sounds like, the vents are clogged with something. I guess, the fan is working inside, of the freezer? Ice in the bottom, of the freezer pan, could be clogging the vents. You'll have to dig deeper. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
Www maytag ca
I HAD A PROBLEM LIKE U ARE HAVING AND I REPLACED THE DEFROST HEATER SENSOR AND IT SOLVED MY PROBLEM.. I AM NOT SURE IF IT IS CALLED THE SAME IN MAYTAG..
Apr 10, 2014 | Maytag Refrigerators
The coils in the. Back of the freezer keep freezing up! I use a hair dryer to thaw...freezes up again...what is wrong
The problem could be in the draining of defrosted ice. The drain may be clogged thus allowing water to back up. Next I would check the fan and make sure it is running. The last thing if that doesn't help is get a refrig specialist to check out evaporator and compressor. Now consider this, if it is much older than 10-12 years old , you may want to replace it. His sometimes is the beginning of the end.
Feb 03, 2013 | Amana ABD2533DES Stainless Steel Bottom...
We have a Kenmore top freezer (no ice maker) refridgerator less than a year old. The frige part is warm while the freezer is frozen. Turns out the vents on the top of the fridge were clogged w ice. We...
Very likely the vents are freezing due to the defrost drain is blocked so instead of the water from the defrost draining into the pan on the bottom as its supposed to its pooling in the freezer and freezing over the air vents.
This tip i wrote will help ya to clear the drain. http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Kenmore Refrigerators
My dryer is Model #GEW9250. I have a problem- sometimes it will dry and sometimes I have to run the same load 2-3 times. I'm not sure what the problem could be. My filter is clean and we did check the...
Unless this is an older unit I would first check the filter and then the exhaust hose for clogs. If the hose has not been cleaned in several years then check that first, remember to do this to reduce fire hazzard. Also check the vent outside the house to see if it is clogged. If you are in colder climate areas and the vent is near bushes check to see if the ice is clogging the vent. (moisture freezes on bushes, if they are too close to the vent) If the "run" of exhaust pipe is long you can use the "blower" of your vacuum (if equiped) to clear the hose,. Note: wach for the mess if the hose is clogged. Good Luck.
Jan 22, 2011 | Whirlpool GEW9250 Electric Dryer
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Samsung RB2155 Bottom Freezer Refrigerator Logo
366 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
