Question about Sanyo DP26648-R 26 in. LCD TV
Pink Bar on left side of Sanyo TV screen
I have a 26" Sanyo LCD HDTV Model DP26648, I don't have digital, and I have Cable TV. Out of nowhere a pink bar appeared on the left side of the screen. After 2 hours it began to fluctuate depending on the sound of a voice or noise on the TV. After being off all night the bar was gone in the morning but about 2-3 hours later the bar was back and its been appearing but then disappears and then is back again. Any ideas what could be wrong and how i could get the bar to go away permanently ?
4 Suggested Answers
  • 21 Answers
SOURCE: pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Posted on Jun 03, 2008
SOURCE: I need to hook up to digital cable
Thank you for your time.
I turned on the router supplied by Verizon, which I did not do yesterday, I'm embarrassed to say....
I called Sanyo and received step by step how to set up.
It was the same procedure I used yesterday with the exception of making sure the router was on,
I apologize for any inconvenience.
Reva L,
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: My Sanyo 26" LCD TV - model DP26648 has sound but only displays a
Turn off and on
Posted on Mar 11, 2010
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
Blue and pink dots displayed on screen
Looks like the display has developed some problem. Try changing the input device to some other like a DVD player, VCR etc. If the problem persists, this might require attention by a qualified service technician.
Jul 13, 2012 | Sanyo DP26648-R 26 in. LCD TV
2008 Sanyo DP26648 has a black screen but has sound
Check its T'Con board. This is a common fault to all type of LCD TVs
Apr 02, 2012 | Sanyo DP26648-R 26 in. LCD TV
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
White screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Jan 11, 2009 | Sanyo DP23625 23 in. LCD Television
Set up lcd tv
Make sure of correct input
HDMI is best
cable box must be set to HDMI
otherwise input to channel 3
Jul 22, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo DP26648-R 26 in. LCD TV Logo
123 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
