Question about NetGear RangeMax WPN824 Router
Can i install my netgear router to my computer
Can i install my netgear router to my computer with no disc
  • 2,460 Answers
Yes. Access to the router is part of the firmware. Set the computer to "Obtain a DHCP address Automatically", plug it into the LAN port(s) of the router, and it should give you an address of 192.168.1.x where x is anything but 1. From Internet Explorer, type in 192.168.1.1 on the address line and press the Green Arrow. It should open up the Netgear server box login. Username is always "admin" (no quotes) and the password by default is "password". If you've changed it, then it might be a problem.
Carl
Posted on Jul 03, 2009
  • 453 Answers
Http://kb.netgear.com/app/products/model/a_id/2630
This page has the firmware download for version 3
Click on the link. Download the firmware and run the file.
Good luck !
  • 854 Answers
Yes...just follow this
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
  • 61 Answers
You can.
Connect the modem to the router's WAN port. Connect your computer to one of the other ports. Find the gateway address from the desktop by going to Start>Run and type CMD. When the black window opens up, type IPCONFIG
That will spit out some information-- your IP address, subnet mask and finally the gateway address (it will probably be something like 192.168.1.1).
Whatever the gateway address is, open up internet explorer (or firefox or whatever browser you use) and put that gateway address in the address window.
That will take you to the router configuration page. Log in, look for a setup wizard and follow it through.
3 Suggested Answers
  • 221 Answers
SOURCE: netgear router DG834GT
To do this you do not need the installation disk.
1. Click Start, Run, CMD, enter. Type 'ipconfig /all' and write down or remember the ip address for your default gateway.
2. open your browser and type http://192.168.1.1 (or whatever the ip address is for your default gateway.) hit enter.
3. In the username and password login screen type admin for both. If this doesn't work, try using admin for just the password, if no luck try again for just the username, until you are logged in.
4. Go to wireless settings, security, and find the part where you can set your wireless password. It is also a good idea to use wpa personal instead of wep, because it is a stronger encryption method.
Posted on Apr 20, 2008
  • 191 Answers
SOURCE: Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Posted on Nov 10, 2009
Hi. i cannot get my new wireless netgear dg834g to connect to the internet. it never came with an installation disc. everything is connected properly. internet light is red not green. i havent been...
To access the Setup Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Mar 06, 2011 | NetGear DG834G Router
I have lost wireless internet connection on both my laptops the net gear box show number 4 flashing ?
my computer and my laptop wont connect to Internet explore.i can not find my netgear disc the computer has asked me to reinstall my wireless netgear disc.
Nov 08, 2010 | NetGear RangeMax WPN824 Router
Hi I'm looking to install a DG834G router to give wireless access but the only instal disc is from AOL and I'm not with them anymore, I have tiscali broadband. How do install the router if it won't plug...
Try NOT using any install disk.
Turn the TISCALI router off.
Turn the NetGear off.
Use an Ethernet cable to connect from the LAN port on the TISCALI router to the WAN port on the router.
Use another Ethenet cable to connect from one LAN port on the router to the network-port on your computer.
Turn the TISCALI on. Wait 60 seconds.
Turn the NetGear on. Wait 60 seconds.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Note that the '123.456' will be some other numbers.
Start Internet Explorer.
Type http://192.168.123.456 (substitute the current values)
Login to the web-server running on the router.
Run the "Wireless Networking Setup Wizard"
to configure a SSID, an encryption-level (use 'WPA')
and a password for your network.
After the router restarts, you should be able to get wireless access, using the SSID and password that you configured your router to use.
Sep 29, 2010 | NetGear DG834G Router
Need help to instal the wireless router WGR614V6...NETGEAR
GO TO CONTROL PANEL AND CLICK NETWORK CONNECTIONS.SEE IF YOU HAVE A LOCAL CONNECTION.IF NOT THEN HOPEFULLY YOU HAVE THE MOTHERBOARD DEVICE CD.THAT`S THE DISC THAT INSTALLS SOUND,NETWORK CONNECTION ETC.YOU WONT NEED A DISC THE ROUTER DISC IF YOU HAVE THAT. I HAVE A LINK SYSTEM AND NEVER EVER USED THE LINK SYSTEM DISC TO TO INSTALL IT.ONCE THE ROUTER IS PLUGGED IN,YOUR COMPUTER WILL DETECT IT.BUT TO BUILD A NETWORK CONNECTION BETWEEN IT AND THE COMPUTER YOU ARE GOING TO HAVE TO HAVE THE MOTHERBOARD DEVICE DISC.IF NOT WELL THEN YOU WILL HAVE TO BRING IT TO YOUR LOCAL COMPUTER TECH SHOP.JUST FOR THE HELL OF IT SHUT DOWN PC,O YEA THIS WILL ONLY WORK IF COMPUTER IS CUSTOM.OPEN PC[MAKE SURE PC IS OFF!] AND SEE IF THE MOTHERBOARD DISC IS TAPED TO THE BASE OF COMPUTER THAT IS IF YOU CANT FIND IT AND YOU PC WAS CUSTOM BUILT.....THEN YOU IN LUCK!
Nov 29, 2009 | NetGear WGR614 Wireless Router
Port forwarding,I am retarded
totally disconnect router from computer reboot system.with your router you should have a install disc.reload the disc and follow the instructions.when you reboot your computer should find your router.hope this is of help.
May 10, 2009 | NetGear DG834G 802.11G Wireless ADSL...
I have an Acer Aspire 8.9....and I need to know what type of router I need to go wireless. I purchased one from Netgear, but it has a disc that must be installed and adapter that has to be used {with...
Aspire one does not have a CD/DVDROM however you can use another computer to be able to setup your router. You can probably ask a friend to use his/her laptop that has a CD/DVD ROM. After setting up the router, you can connect your Acer Aspire by letting it detect the wireless signal and connecting to your router wirelessly.
**You can also try to insert the installer disc on another PC and copy all the contents of the CD/DVD installer of the Netgear into a USB flash Drive. Plug the USB flash Drive into your Acer then run the setup file inside and follow the instructions.
Oct 26, 2008 | Computers & Internet
Install netgear wgr614
Well which version of that router are you using - there are 9 different version of that model of router - you can find it most likely on the bottom of it on a sticker - find your version and here is a link to getting the manual for your versioin - the manual will tell you how to set it up by using your browser instead of the CD - if you have any problems then i can help you - just let me know. Thanks.
Sep 03, 2008 | NetGear WGR614 Wireless Router
Netgear dg 834gt modem
download from netgear site also manual in PDF format
Nov 09, 2007 | NetGear DG834G Router
NetGear RangeMax WPN824 Router Logo
145 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
