Home | Dometic | RM2652 Refrigerator | My Dometic trailer ref...
Dometic RM2652 Refrigerator
Problem for Dometic RM2652 Refrigerator
My Dometic trailer refridgerator is warm but freezer is freezing.
By brandi4723 on Jul 03, 2009
The freezer is working, but the refridgerator is warm, and when I open it there is a strong amonia smell present.
Solution #1
posted on Jul 03, 2009
Not Rated)
jeffmyers_20
Rank: Guru
Rating: 96%, 66 votes
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Was this helpful?
Yes
No
Popular Solutions for Dometic RM2652 Refrigerator
Questions and Unsolved Problems for Dometic RM2652 Refrigerator
Do you recommend Dometic RM2652 Refrigerator?
Answer
Answer
How do you regulate Dometic to stay at 36 degrees. Our Dometic gets down to 26 and 24 degrees, which... (More)
Answer
the fc 140 will go down to -17 degrees f. when pluged into 120 volts but will only go to 27 degrees... (More)
Answer
the fridge freezes everything! even the stuff towards the bottom of the fridge. Milk, fruit,... (More)
Answer
won't cool. electric elementin amonia tank is hot.
Answer
My Dometic RV fridge RM 2652 seems to get too cold. The produce in the fridge get frozen no matter... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic RM2652 Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
