Question about Mitsubishi WD Televison & Video
Vertical hold problem on 1999 Mitsubishi rear projection VS 50605 can't find reset button.
  • 985 Answers
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Posted on Sep 14, 2014
SOURCE:
Vertical hold problem on mitsubishi rear projection VS 50605 can't find reset button. Where can I find it.
Your Vertcal Hold Problem Is Due To Lack O f( Sync) Hold Which Is Usually Caused By Defective Filtering In The Vertical Output Circuit
Sep 10, 2014 | Mitsubishi WD Televison & Video
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Mitsubishi VS-50605 - no vertical control until it warms up and it is now starting to flash to a black screen
Howdy,
CHECK AND REPLCE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR) BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Dec 29, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
