GRAVITY USUALLY LOWERS THIS WING, BUT EVEN SHOVING DOWN WITH A LOADER, IT WILL NOT GO DOWN. WOULD APPRECIATE SOME IDEAS. THANKS.
Just an idea but my guess is that it is in the hydraulic system.
Probably a safety valve that prevents it from falling in case of a hydraulic line break.
Link to JD answer center.
Answer Center from JohnDeere
SOURCE: JD X320 blades stay engaged, always. Narrowed it
Hi you can adjust the gap on these clutches , The recomended gap is 0.10 thou you slide this size feeler guage into the hole on the side of the clutch there is three holes and three adjusting nuts you have to try and get it even .
Hope this is some help
Mark.
SOURCE: 1545 jd mower
Hi Craig, sorry to hear your having problems. the first thing to try is running the machine with the fuel cap loose. The cap has a vent that allows air into the tank as the fuel is consumed.
Ensure that the cooling shrouds are clear of and grass / debri buildup causing it to over heat.
If those fail, it is likely that you will need a new ignition module. As the module heats up it expands. if there are any weak spots it will cause a broken internal connection when expanded. When it cools off, it contracts and the weak connection is restored.
Kevin
