Question about Ryobi Garden
Replacing fuel lines on ryobi 767r trimmer
I'm replacing fuel lines on ryobi 767r trimmer that disintigrated from old age. Two lines from tank. One to primer bulb and one to carb. Which one goes to the bottom of the carb?
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 05, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
  • Kerry McKinney
    Kerry McKinney Sep 23, 2014
    Jim i need to replace primmer to tank line and don't no what tool is needed to get to coupling inside tank??
Replaced te fuel lines. no sure Ihavethe lines connected properly
Not sure if your primer bulb is on the carb or separate but here are some basics... The smaller line is the main fuel line. It has the fuel filter on it and the filter should be laying on the bottom of the tank. That line goes to the fuel pump side of the carb ( usually the inlet near the center of the carb body ). The fuel goes through the filter up the main line and fills the carb then to the primer bulb whether its on the carb or separate. If on the carb the spigot closest to the primer bulb takes the larger line and returns to the tank. That line should go into the tank about half an inch and terminate. If the primer is separate the larger line leave the carb from the spigot on the metering side ( usually close to the edge of the carb body) to the inlet of the primer bulb then from the primer bulb out ( usually center of the bulb) to the tank and terminates about half an inch inside the tank. Remember... fuel filter into carb, carb to primer bulb, primer bulb to tank. If the fuel does not go that direction when the bulb is primed then you have lines hooked up backwards.
Aug 03, 2014 | Ryobi Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Need diagram for fuel hoses for a garden hawk trimmer. which hoses goes into what inlet of carby
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Feb 27, 2011 | Ryobi Garden
I need the fuel/oil mixture for Ryobi 31cc 775r gas weedeater. Also the diaphram for the fuel line replacement.
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
Jan 09, 2011 | Ryobi Garden
I have a Ryobi 700r trimmer - I needs a diagram of all the fuel line hookups
<div id="ms__id6" class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.<br />If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.</span> </div><!-- from fixya rte -->
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing fuel lines on ryobi weed eater,need
Jul 10, 2010 | Craftsman Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 768r fuel line
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
754 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
