Question about Belkin Computers & Internet
Belkin N+ Router as a repeater
I am trying to send a wireless signal from my one house to another one I own that is about 100 feet away (corner to corner). I just purchased two of the Belkin N+ routers because I read that they tested at having the most range. Well I am still not quite capable of getting just one to work at the other house and I was wondering if I could set up the other to work as a repeater.
Is that what the Access Point is? How do I do it? I can't get third party firmware, can I?
Can you suggest a better router for me to buy?
  • Mark Ebner Jul 03, 2009
    Would both need the better antennas? On my old router (a Trendnet 54 G) I replaced the antenna with a 12 dBi antenna and didn't notice much increased range...is that because my computer didn't have the strength to transmit back?
    President:
  • 623 Answers
Whow...so many questions...I will try to touch at least a couple of them...;-)
  • You're right about the range - these routers have a very good range.
  • Terminology: An Access Point is a router like when you getit fresh from the store. "Access" means that the router gives yourLocal Area Network (LAN) access to another network or WAN (wide areanetwork). This other network for home users is usually the internet, orit can be a company network in a business setting.
  • Your second router would be a Bridge, because it "bridges" the network from your second to your first router.
    Take a look at this diagram - this is what you want to build.
  • You will need a third party firmware to achieve this goal - stockfirmware is not able to do that (They rather have you buy anotherproduct...) If your routers is capableof running another firmware depends on your model. Take a look at the "Supported Hardware" page of dd-wrt ( link),type in "Belkin" and see what you can find out about your specificmodel. I read in other places that people were complaining about Belkinregarding 3rd party firmware, but things might have changed.
  • I have a setup like that and use Linksys WRT-54G routers. They are cheap (around 30$) and are able to run tomato firmware (link). They also have two antennas, which means one can be set to receive the signal and the other one to send it.
  • Last resort: Can you run a cable to the other house? That wouldalso eleminate all nasty influences a wireless signal is prone to(reflection,interference, security etc.)
Well - I hope I could shine a little bit of light on your project. Ifyou have any more questions, just come back here and leave a comment -I'm happy to help.
Posted on Jul 03, 2009
  •  C. Dante
    C. Dante Jul 03, 2009
    With "both" do you mean the Linksys routers? Mine are about 50ft apart and I did not exchange the standard antennas. Better antennas give usually a boost in signal strength, so I wonder why it didn't work on your Trendnet router. Wireless signals are affected by many things: Interference in the same signal spectrum (802.11g/2.4 MHz: Microwaves, cordless phones). Power lines. The weather (refraction) can affect the quality, objects can bend the signal (difraction).
    Third party firmwares often gives you the option to modify the transmit power (standardL 42 mW) from 1-251mW. I changed mine to 60 mW, which does not heat up the router too much. Sometimes even a simple trick like this or this can help you to get a better signal.
  • 2,460 Answers
I can always suggest a better solution, called Wireless Access Points. I use the TP Link brand, because they're inexpensive, have detachable antennas, and can be used as a WAP, Client, Repeater, or Point to Point/Multipoint (means you only need to stock one unit for many functions).
http://www.tplink.com/products/product_des.asp?id=116
Price is about $60 and you can spend $10-50 on a different antenna.
Carl
What are my options to deal w/ dead spots in my home - wrt310n
First, it is all about placement of your router. try to put your router in an open space, not too high up, not too low down. Keep objects away from it and keep it out of the corner.
Second, If these do not cut down on dead spots, you need to get a wireless repeater. A repeater repeats the wireless signal from farther away. Its like a second router that is closer, so you can get better signal.
Mar 06, 2011 | Linksys WRT310N Wireless Router
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
My Belkin N-1 is very weak. Can't get a signal from one room to the next. Is there a fix or does it need repair?
Try changing the channels on your router... Also, if you have a wireless phone near it make sure that they are using different channels or better to move it away from your router... very thick walls also weakens the signal... try placing it first near your laptop just to check that you can connect wirelessly before you move it away... you might just need an range expander or repeater to boost up the signal
Mar 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Any way to boost signal. I don't recieve the signal very well at my sister's house which is three doors down (less 300 feet). Sometimes access the net from here house and its not a strong signal. My...
Unfortunately the range on a G router is usually reliable to about 200 ft or so, depending on obstructions. There is no way to boost the 802.11g signal. You'd be looking at upgrading your router and card to 802.11n, which would give you increased range. .
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need a stronger signal for the wireles in our house
Your better off getting a repeater for your wireless and strategically place it in a room where it can amplify to the next and so on. Concrete is virtually impossible to pass through with the signals wireless transmit so a repeater strategically placed is the best way in my opinion.
Jan 30, 2009 | 2wire (1000-100016-002) Wireless Adapter
Wireless Networking
try this this is a very very good info site
Apr 24, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Belkin Universal Wireless Extender Set-Up Problems
Have you tried restarting and resetting the router as well ?
Feb 06, 2008 | Belkin (F5D7231-4) Wireless Router
Error: 80410A0B
The range of your Wi-Fi network will depend on the layout of your house. In an ideal environment, such as the wide-open expanse of a parking lot, a Wi-Fi network's theoretical range can exceed 500 feet. Inside the typical home, however, expect anywhere from 75 to 150 feet, depending on the layout and the amount and density of obstacles. In our repeater-equipped setup, we were able to achieve close to 100 percent signal strength in a distant corner of the house where the signal had been either very weak or nonexistent. We tested the signal strength using Buffalo's included AirStation Client Manager software, which we installed on our notebook. The handy applet, which takes control of your notebook's Wi-Fi radio, displays such pertinent information as the name of your network, its IP and MAC addresses, and, of course, the signal strength. If necessary, you can extend your signal strength even further by adding repeaters. The WDS protocol allows you to link six repeaters to a central router. Just keep in mind that each time you add a device, you cut your maximum bandwidth in half. An extended 802.11g network consisting of a router and a repeater will have a maximum speed of 27Mbps, for instance. The same Wi-Fi network with a router and two repeaters will top out at 13.5Mbps.
Mar 18, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
9,232 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
