Question about Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w
My brother DCP-J140W printer ink box full .. please help how to fix it.
MODEL DCP - J140W 120451 - 11 TYPE ACCEPTED NO : ESD-1004477C MACHINE SN -E70957G3F 197790*
    Sergeant:
  • 269 Answers
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
Posted on Sep 09, 2014
SOURCE:
naresh_sh695
SOURCE: The ink absorber near full Problem with my brother
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
Posted on May 07, 2012
Soulvisitor
  • 1113 Answers
SOURCE: I need total reset for a Brother dcp 115c
Your print head is stuffed. More expensive than new machine, Release your frustration with this unit by placing neatly in bin!
4F
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
why
Piezoelectric (PZT)
ceramic actuator
defective (Cracks or
rare short)
Posted on Feb 07, 2008
SOURCE: Printer is unable to print
EXPIRY GUIDE
Posted on Sep 05, 2008
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
  • 8 Answers
SOURCE: Brother DCP-195C Compact Colour Inkjet ... i have
Brother DCP-195C Compact Colour Inkjet error unable clean 46
Posted on Sep 07, 2010
My brother printer j140w problem massage coming on screen "ink box full"
It may refer to the ink "overflow" box. When your printer cycles, it will dump a bit of ink which goes into a collection box. Most likely, that box is full and needs to be emptied, replaced, or whatever.
Dec 24, 2016 | Brother DCP-J140W
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
Jul 22, 2016 | Brother Dcp J140w - Multifunct
Ink box near full
heres the solution for ink box near full
1 power on the printer
2.press menu, mono, menu
3 press arrow up or arrow down look number 8 then press ok
4.press arrow up or arrow down look number 0 then press ok
5.press arrow up or arrow down PURGE Counter then press 2783
6.press 99 to exit maintenance mode or unplug the machine
7.turn back on the printer
Jun 23, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
How to fix brother dcp J140 message unable to init 4f?
Error 4f means that your carete is damaged, probable after using not oryginal cartridges, it's reportable but to expensive. If you used brother ink, you can do an complaint I in brother service point.
Feb 16, 2015 | Brother DCP-J140W
I have a brother J140 W i followed your instructions to clear purge full ink box and it worked,I thought great,But now when i print the black ink goes into the yellow when I do a test I have 2 black i cyan...
Did you actually change any parts or just reset a warning? If you were getting a full error, chances are the purge system was full and needs to be changed. Likely what the problem you are having is that ink from the purge system is backing up and polluting your print heads.
Jan 04, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
How to solve the problem of see troubleshooting and routine maintence chapter in users guide in .it unable 4f in dcp-j140w wifi brother printer
A print unable message in a Brother inkjet usually means the waste ink chamber is full. This can be fixed by removing the waste bottle, cleaning and drying the pads inside, then reassembling the machine and resetting the purge counter. Most of the instructions for this can be found on u-tube. Please note it is a messy job and many folk just replace the machine.
Dec 03, 2014 | Brother DCP-J140W
How to change the ink box
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
Other reasons for cleaning are:
  1. The machine automatically cleans after clearing a printer jam.
  2. The machine automatically cleans itself after sitting idle for more than 45 days (infrequent use).
  3. The machine automatically cleans itself after the ink cartridges have been replaced 12 times.
If your question was not answered, please check...
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002700/000051/faq002751_003.html?reg=us&c=us_ot&lang=en&prod=dcpj140w_all
OR
If You Still Need Assistance Then Follow Us For ON :
Brother Printer Support
Feb 03, 2014 | Brother DCP-J140W
Hello, I have a Brother DCP-J140W printer and the
You can still print in black using the 3 colors. See the printer configuration. After a while it will clear up.
Sep 28, 2013 | Brother DCP-J140W
Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
886 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
