Question about Sunbeam 2350 Heritage Series Mixer
Where to buy parts
Gears are bad where can I order parts
    President:
  • 3,433 Answers
Braun Coffee Grinder Mill Part - theEssentials.com Shop theEssentials.com for a wide variety of
Posted on Jul 14, 2009
Where can I get plastic gears that turn the beaters of an unidentified mixer?
You contact the unidentified mixer service agent and order the parts from them. If it is a cheap unidentified brand or model then expect there to be no parts at all.
Dec 22, 2015 | Food Mixers
I need the gears for a 2346 sunbeam stand mixer
You can try contacting your chamber of commerce for a reputable dealer or repair station. Or try https://www.ereplacementparts.com/
Nov 07, 2014 | Sunbeam 2346 Heritage MixMaster Series...
Motor noise
It has been my experience with knocking kitchenaid is one of three reasons all related to the speed control of the mixer1 speed control board adjust speed screws2 speed Phase control board, needs replacing3 The motor governor behind the speed control board needs replacing
Speed board = $9.00Phase Board = $20.00Governor = $10.00Your time + one week for ordered parts asnd one hour to remove and replace.
all work is performed at the rear of the mixer and you need only a phillips #2 screwdriver, a pair of needle nose pliers, an 11/32 open end wrench (you will need this to adjust your speed control board after new install) and that's it. easy work all remove and replace. Oh! make sure that you pit some thermal paste behind the phase control board to avoid burn out.
But!!! before you buy parts and do all that, try adjusting the speed contol board first. Go here for a parts list for your model.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KV25G0X&siteCd=KAD&userType=Servicer
then go here for instructions on tuning the mixer speed.
http://www.youtube.com/watch?v=pUo_ZU5xh3o
if after you tune it you still get the knocking then use the parts list to order parts. two good parts sources are goodmans.com and mendingshed,com, they are reliable and have the parts in stock.
Aug 26, 2012 | KitchenAid KV25G0X Stand Mixer
I have problem with the gears of the mixer sunbean 2343. Since I can buy all the pieces that compose the system
Please clarify your question. I understand that you are thinking of buying replacement parts for the mixer to correct the gear problem. Is that correct?
Jul 29, 2011 | Sunbeam 2346 Heritage MixMaster Series...
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
My K45SS mixer makes a LOT of noise lately. I've seen a lot of ads for replacement gears. How do you replace the gears ?
brooksite, Sorry to hear you mixer is making a lot of noise... They shouldn't do that. Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. You may find that it's just one particular gear that's causing the noise.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor had the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Also, here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Good luck and have fun. I hope this helps. Howard, Burke, VA
Nov 05, 2009 | KitchenAid K45SS Classic Stand Mixer
Brown oily substance is leaking out of the mixer
It's the gear lubricant. It's food grade so no panic of contaminated food required. When it is all done leaking you may need to buy a new mixer or order a repair kit and open it up before the gears get ruined. - good luck- Ned-
Aug 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I make bread in my 620 series mixer and
Remove the upper hslf of motor housing (unplug first) and ck it out. If all looks ok, put some food grade grease on the gears and mix on! If there is alot of metal, the gears are worn and should be replaced. If you order gears, order brushes also. The carbon blocks with springs behind them on opposite. end. They really are quite simple once you get into it. Good uck.
Aug 22, 2009 | Food Mixers
Sunbeam 2350 Heritage Series Mixer Logo
200 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
