Question about GE Microwave Ovens
Believe I have a bad door microswitch and probably the latch assy. Do I need to take the unit down to repair it?
Model JVM1650WB005, s/n TZ9084085. can I tear this down far enough to replace the switches without taking it down?
  • GE Master
  • 2,940 Answers
Most likely you'll need to pull the cover off. If you can't pull the cover off with the unit where it is, then you'll need to take it down.
Posted on Sep 11, 2014
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Microswitch nomenclature
These are the OEM switches in that model: SWITCH-SECONDARY part # WB24X0829 reference # 1446 (it needs 2) SWITCH-MONITOR part # WB24X0830 reference # 1447 But... You can use a generic 15A three-terminal switch in each spot as long as the proper wire is attached to each of the the "C" (common), "NO" (normally open) and "NC" (normally closed) terminals. These replacements are available from a local appliance parts store, home improvement center, or Wal-Mart, etc. As far as the door latch is concerned, reference 1205 is listed as the "body latch". I usually call it the door switch mount. The tabs on the door switch mount sometimes break. If it is removed, the door has to be realigned and a leakage test must be done. But often one can fix it with epoxy, etc. without removing it. You need to also check to be sure the hooklike devices sticking out of the door are not broken off and that they have spring tension which pulls them back down after you push up on them. Sometiems the inner door screen has a little loop to which the spring mounts, and that loop breaks off inside. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Also, there should be a mini-manual / tech sheet folded up inside the oven. It's very helpful. Another good source of parts lists and exploded views diagrams is http://www3.sears.com (the 3 is correct). Your model is there. Another part source for this one: http://tinyurl.com/gv383 Good luck, be careful and be safe.
Posted on Jun 15, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: the door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 23, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: Dacor DMO24 microwave oven door stuck
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed. Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Dacors are made by Sharp, and one of these service manuals below may help you.
http://www.microwavedisplay.com/r530es_sm.pdf
http://www.microwavedisplay.com/R530EKF_R530ESF_R530EWF_sm.pdf
http://www.microwavedisplay.com/r530bk_bw_sm.pdf
To order Dacor parts, I recommend you visit http://www.apdepot.com/index.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Broken door latch on Model 63679 Kenmore Elite Microwave.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
Posted on Jan 18, 2009
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Kenmore model 721.63653 I have to hold door up and in for the switch to connect so the oven will work. My son ordered the needed switches to repair this problem, but I cannot find a repair manual online....
Remove outer cabinet. Identify the bad switch in the latch assembly. The microswitches are held in by a plastic tab. Remove the electrical connections and note their location.Carefully push tab aside and the switch will pivot on one of the mounting holes. Be careful. The plastic tab can easily be broken if you use excessive force.
Dec 02, 2017 | Kenmore Microwave Ovens
Stopped cooking
This is technical!!! Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right inside of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 30, 2018 | Advent Mw912bwdk Black Built-in Microwave...
On my emerson microwave model mw81195b, with the door closed on the unit cycled out a fan is still running. The only way to cycle the unit off is to open the door. The microwave functions fine except for...
I'm fairly sure the fan has a door switch and that may have failed. if you take the outer cover off the micro wave itself you hopefully will have a wiring diagram of the unit. Many times I have had to replace micro wave door switch's that have failed not letting it start or sometimes such as yours something like the light staying on. Being that you are a service man, I don't have to tell you be sure to disconnect the power to it and then you can use your ohm meter to check the switches. Hope this helps you
Sep 08, 2017 | Emerson Microwave Ovens
I have a sharp carousel microwave. I was heating food and in the middle of heating the microwave stopped and the timer continued to run. What could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 05, 2010 | Sharp Microwave Ovens
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
I have a Panasonic microwave NN-V689W where the door latch will no longer engage the microswitch. Where can I get a full parts list for this model?
You will need to check out from the Panasonic service centre ( try a search for this model) but the best will be to try to get a salvaged door assembly unit. Mostly many sets have their panel pads or electronic boards damaged leadding to scrapping the set. So if you can try you will be able to easily source all the reqired spares or the fully door assembly from a scrap dealer / repair shop. Also try to improvise with a latch for triggering the limit mocro switch. You can attach some plastic to be welded to the door latch so as to push the limit switch. at least for the time being or even use another limit switch with an extended stem. Hope you try this out. Good day .
Aug 11, 2010 | Panasonic Microwave Ovens
Kenmore model 911.4942993 microwave does not defrost or heat. All keyboard functions appear to be normal. Are there onboard diagnostics for this model? This unit is part of a built-in oven with microwave,...
This was my first microwave oven repair, and I feared the worst - big $$$'s, parts no longer available, etc. But after I pulled the unit forward and found the schematic diagram, it turned out to be a defective microswitch in the secondary door latch circuit.
Even in retirement, my degrees in electronics and computer science occasionally save me some $$$'s.
Aug 05, 2008 | Roper Microwave Ovens
Smeg microwave working but not heating/defrosting etc. SA35MX model.
if it makes a loud humming sound it is something in the high voltage circuit. it could also be a bad microswitch in the door latch assembly
Apr 24, 2008 | Microwave Ovens
Jun 13, 2007 | GE JE1590 Convection / Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
