SOURCE: Suddenly cannot scan with HP J4680 All in one
Issue
When using the
Scan To
function on the control panel of a USB-connected product, '
No Scan Options: Refer to device documentation to troubleshoot
' appears on the control panel display.
NOTE:
Follow
these steps in the order presented to resolve the issue. It is not
necessary to continue to further steps once the issue is resolved.
Solution one: Make sure that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the
Scan To
function to work. If it is running, the DIM icon (
) is present in the notification area. The notification area is located in the lower-right corner of the computer by the clock.
Figure 1: Notification area
If the DIM icon is in the system tray, you do not need to complete this procedure. Skip to the next solution.
Follow these steps to set the computer to run the DIM.
Solution two: Populate the destination list
You must populate the destination list in HP Solution Center for the
Scan To
function to work. Follow these steps to populate the destination list.
NOTE:
HP
Solution Center is the software that came with the product. You must
make sure the software is installed on the computer for all the product
functions to work correctly. The software is also necessary for
completing this procedure. Install HP Solution Center if it is not
already installed.
Now you should be able to scan from the printer
NOTE:
It might take several minutes for the list to populate.
If
the appropriate programs are already listed as scan destinations,
discontinue this procedure. You must reinstall the software.
Testimonial: "Great answer!"
SOURCE: HP officejet 6500 709n will not scan manually,
Try This :
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L3 file;
If you don't have the Cd Uninstall the software from Add and remove programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-67766-1&lc=en&dlc=en&cc=us&lang=en&os=2100&product=3795406
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
This should resolve your Issue
Regards Soumajit
SOURCE: how to install driver for hp officejet j4680 all
Have you got an installation CD or downloaded the printer driver?
If not you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
www.hp.com/#Support
Then click on the downloaded file to install the printer driver.
SOURCE: owners manual for HP Officejet J4680
Please find for yourself a free copy of the manual by clicking on the link below:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3692888&lc=en&cc=us&dlc=en&lang=en&cc=us
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
SOURCE: how to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
If you need more help come back.Post /
thumbs / testimonial are
welcome!
