Question about Magellan RoadMate 1412 Car GPS Receiver
The pin with which we charge the GPS was broke. is there anyway that we can open the GPS and fix it?
  • manikiran_p Feb 20, 2010
    hi Zhan, thank you for your suggestion. But I am sorry to say that, I can't find any screws to open that. Is there anyway that you can tell me where the screws are?
  • 377 Answers
No you cannot open it if the unit is under warranty call magellan and let them repair it but if the unit is no longer under a warranty magellan have a customer loyalty program were you can swap your old unit for a new one with a discounted price.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Posted on Jul 03, 2009
  • 3 Answers
You may open the unit and solder the pins. I had one with the same problem after three months. Fixed first time, broken again and had to fix the 2nd time. It was not a good design
Posted on Jul 10, 2009
Can't add any addtional addresses in favorites (address book) have deleted many listings but still won't accept new ones ruth
Posted on Feb 20, 2010
I have a Motorola gps that fell and landed on the usb charger plug and broke the pin off the board. the battery is a sanyot0052 with 4 wires . Can you tell how i can charge this battery via the 4 wires so...
Don't try and charge the battery directly, as it is a lithium battery it can explode if not charged correctly.
You can try connecting (soldering) wires to the circuit board where the socket was connected to feed in 5V from the power adaptor or USB lead.
Mar 08, 2011 | GPS
Pin code unlock
You have Garmin Lock activated and there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
May 31, 2010 | Garmin nuvi 200W GPS Receiver
I have a garmin 238 gps and 2 pins on the back broke off. How can i get them repaired. I live in the cayman islands
More than likely they broke off due to corrosion. Are these the power pins? You can send it to either garmin and pay a flat rate fee, or to Mid-Shore Electronics in Ocean City, MD. 410-228-7335. I hear they do pretty good work.
Oct 29, 2009 | Garmin GPSMAP 238 GPS Receiver
My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
Nov 10, 2008 | Magellan Maestro 3225 Car GPS Receiver
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Dec 03, 2007 | Navman PiN 570 GPS Receiver
Reparation
power pin probably came loose. If you can open up the unit and re-solder the power connector to the board. If you need more assistance re-post and I'll tell you in further detail. Also, make sure the end of your power cable is getting juice.. flow.. is hot? live? has power to it.
Sep 19, 2007 | Magellan RoadMate 3000T GPS Receiver
Broken Power adapter
external power adapter? if you broke open the gps receiver and used any glue make sure you didnt coat the silver looking tiny metal parts or you just insulated them from the power adapter.. scrape off the glue gently with a small flat screwdriver. double check your wires to it the center conductor is usually white or red but the outer is ground or copper braid or black wire also check and make sure you didnt solder splash short the connector. gently tug on both wires if they bust loose you need to resolder proper 60-40 rosin core. adapter problems is easy . get a meter and check for voltage out from it should be like 14 if rated 12v. also you can just plug it up and trace to point where the voltage is lost to battery. good luck
Aug 21, 2007 | Navman F20 GPS Receiver
Getting a fix status.
Did you try setting the time precisely for your location - then wait a minute?
Apr 30, 2007 | Standard Horizon CP170C GPS Receiver
Magellan RoadMate 1412 Car GPS Receiver Logo
213 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
