Cell phone
SOURCE: Phone Lock - Samsung SGH-X670
The Phone-Lock is a manually set code, this means that you or the previous owner set this code on the phone to prevent it from being stolen. Consult the previous owner to get this code. Second option is to have Samsung remove this code for you, but this option usually costs money. SIM-lock can be removed by contacting the provider the phone is locked to.
SOURCE: subsidy code
Phones are locked to their carrier so you cannot switch carriers with that phone. The subsidy code is a code that will unlock the phone so it can be used on different carriers. You can get that code from the previous carrier if they are nice enough. But most won't because you are not a customer anymore. Here is a way i recommended a T-mobile customer to get their phone unlocked for cingular.:
There are a couple of ways to do this, one is completely safe and the other is fairly safe, but may require you to mail the phone in to someone to have this done.
The best way is if you are still a T-Mobile customer, to call them and have some good reason to use it on a different carrier. The best excuse is that you will be traveling overseas and want to use carriers there so the calls will be cheaper. Do not let on that you will be switching carriers. They did my Razr for me and it took about 3 days for the code. When you call customer service, just tell them that you want to submit a sim unlock request. They will transfer you to a different department. They will gather info (like the phones serial number) and will email you the unlock code. Their website says that they will only unlock one phone per account every 90 days. But they unlocked 2 phones for me in the same phone call (both were razr's). Once you unlock it it can be used on any carrier except Verizon and Sprint (different technologies). Then just switch carriers. For more info on this you can go to T-Mobile.com and type in "sim unlock request" in the search box.
The other way, which may include mailing your phone to a stranger is having someone unlock it for you. There are services on-line that will do this. Some can do it without mailing the phone to them. But some require you to mail it to them so they can unlock it with a cable instead of the code. The usual cost is about $20.00
But the best way if you are not with T-Mobile anymore is to call around to authorized retailers and ask if the unlock phones. Some do it for about $20 (but no mailing it in risk) and some do it for free is you sign up to a new carrier through them. They want your business any way they can get it.
SOURCE: South African Vodacom Settings for P910i
you have to contact vodacom customer care. settings could be recieved through service provider only it can be delivered to you by a network you are using.
SOURCE: How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
