Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Developed slight vibration,finished mowing ,now it will not start
The tractor is a 2009 Husqvarna, 20HP single ,46 " cut.
Mower cranks but will not move. Please help
Posted on Aug 09, 2009
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Only starts if mower lever engaged (without drive belt)
Sounds very strange but i would guess either a micro switch or one of the relays behind the dash.
Dec 16, 2017 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I don't kown anything about charging batteries! How do I carge a battery in a 2008 Husqvarna riding lawn more?
mille get yourself a cooler and put 8 cold beers in it. Put that cooler into the gap between the seat and the "dash" of the mower. Make sure your gas and oil are good. Have someone jump start your mower from a car and then you mow and drink and mow and drink until the beer is all gone. If the mower does not start from the battery the next day go out and buy yourself a new battery. If the battery and charging system are good then you do not have to charge it if it is being used regularly.
Apr 20, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
216 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
