Question about Canon imageRUNNER C3200 Copier
Canon iR 3220 printer problem with PDF files
I have a Canon iR C3220 that messes up every PDF i print the other printers in my office will print the same PDF with no problems, also the iR C3220 works fine for all other programs. I am using Adobe Acrobat 8.0
  • 2 more comments
  • BSI-IT Nov 14, 2007
    I have done this 3 times now, Canon says I have the correct driver installed and because there are no problems with any other application (i.e. word) the print driver is not the issue.
    Ok... But this only started after my upgrade to Adobe 8.0, PDFs that printed fine under 6.0 now mess up when printed in 8.0. How do I change settings of the driver?
  • Anonymous Mar 24, 2014
    all other printing ok
  • Anonymous Mar 27, 2014
    Adobe 9 standard or adobe reader will not collate on this printer. But word documents work just fine.
  • Canon Master
  • 1,113 Answers
Sound like a driver issue, reinstall and check that it is correct one.
Posted on Nov 09, 2007
  • 1 more comment
  • Soulvisitor
    Soulvisitor Nov 14, 2007
    Printer must need more memory or there is a option in driver that is misselected, it may print fine in word but a pdf uses more memory that a doc.
  • Soulvisitor
    Soulvisitor Nov 15, 2007
    Must be conflict with v8 and driver. More of a Adobe problem than anything else.
  • Soulvisitor
    printers and faxs, find printer icon for canon, right click, properties
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
IRC 3220 Color Copier when printing pdf files is very slow. A 2 page document takes 2 hours to print. please help.
Hello pd.
I suggest you remove and re-install your print driver and make sure you install the CANON UFRII print driver available at the Canon web site. Also, Adobe 8.0 has a known problem with this and you can go to their website and they have a patch for this problem, I hope this helps.
Feb 16, 2011 | Canon imageRUNNER C3220 Color Copier
How do you get into service mode on the canon irc3220 ?
To enter the service mode on the 3220 just press "additional functions" key then press 2 and 8 at the same time then press the additional functions key again. Be very careful what you do in the service mode as you can mess things up quickly if you change the wrong settings.
Good Luck and Thank You for using Fixya
WheatlandServices
Jan 24, 2011 | Canon Color C3220 Copier - Color...
Have Cannon image runner iR 3300. It is networked to our computer. It prints some pdf files and some of them it doesn't print.
This is probably a Adobe problem, but i might know how to fix it. When selecting the printer you want to use in Adobe reader, press the "Advanced" button at the bottom of the window. Press the "Print as picture" box. This should probably fix it.
Nov 12, 2010 | Canon imageRUNNER C3220 Color Copier
Canon iR 3220 PS driver printer problem with PowerPoint 07 files
Is it that two other pcs can print to that same printer?
If so are they using a different version of the driver, ttry reinstalling the driver on the non working pc making sure the port settings are correct.
Mar 23, 2009 | Canon Office Equipment & Supplies
Canon IR 3220 Display panel won't go on
its not ur connecter, try ur power supply board
Dec 18, 2008 | Canon imageRUNNER C3220 Color Copier
Canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1  or  -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
Sep 02, 2008 | Canon imageRUNNER C3220 Color Copier
Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Aug 01, 2008 | Canon Color C3220 Copier - Color...
Canon imageRUNNER C3200 Copier Logo
953 people viewed this question
old marine
old marine
