Question about Goldstar M5200R Air Conditioner
AC not blowing Cold Air
I have the Goldstar Energy AC and it was blowing cold air strong. now the air comes out but its not as cold as it was b4. there b ice on the fridge part and i remove it but still no cold air. Wut do i do?
  • youwantit25 Jul 03, 2009
    ok thank you for your help. Im goin to try each step as soon as i get off work today!
  • 6,927 Answers
Take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Posted on Jul 03, 2009
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
Jan 18, 2013 | Goldstar Heating & Cooling
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
My durango is 2002 the AC has not cooled in a long time so I recharged it today. It gets cold now but the tech suggested I look into the issue of the vents not blowing very strong. Especially the rear...
The vents and doors in most all vehicles have a small amoun of sponge like material around the edges. Often this material deteriorated over time. This is often what causes this
Jun 17, 2011 | Dodge Durango Cars & Trucks
Ac not cold
mcdevito75 here 90% chance your low on freon, you don"t cahrge it the a.c repair shop does, you"d need the gas first and it's a commercial item then the tools would cost you the same if you charged it anyway and the shop gives a guarantee.
Jun 21, 2010 | Goldstar M5200R Air Conditioner
The ac is a window unit its blowing air out strongly but the air coming out is not cold
Make sure the condenser fan is running. That is the one that blows hot air outside. Also see if you can tell if the compressor is running. There is a discharge line and a suction line on the compressor. The suction line should feel cold and the discharge line will be very hot. If the condenser fan and compressor are both running then you may need to get the refrigerant charge checked.
Jun 04, 2010 | Kenmore Heating & Cooling
Air is not coming out
It sounds like you need a fan motor, but it's very possible there is another issue causing that problem. Having it checked out by an HVAC tech is will give you the definitive answer. It's possilbe your local handyman shop could fix it if the problem is only with the motor. Depending on the age of the unit it might be cheaper to replace it.
May 26, 2010 | Goldstar R1804 Air Conditioner
Doesn't blow out very strong any more and doesn't get very cold.
try cleaning the coils..this has the metal fins on it looks like a radiator on a car. Use soapy water and a wire brush. Keep filter clean
Aug 11, 2009 | Goldstar R5050 Air Conditioner
Not blowing cold air
There is a problem and you or an Ac technician has to find it.
Jul 08, 2009 | Goldstar R5050 Air Conditioner
Cold AC but weak Airflow---Also Driver side not as cold as passenger
The air doors are controlled by actuators that on of them or so may need replacing.
May 09, 2009 | Cadillac Seville Cars & Trucks
2001 Aztek blowing cold air (strong) on left side of the car.
This is a blend door problem, this door diverts air either throgh the heater core or the AC accumulator core, it either provides hot, cold or a mixture or blend, this door is deep in the dash and in most cases the dash must be removed to service the little electric motor that operated the door.
Nov 20, 2008 | 2002 Pontiac Aztek
Goldstar M5200R Air Conditioner Logo
697 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
