Blue is shifted up and curves out toward the corners. Convergence correction works for the red, but only horizontally for the blue. Is this fixable? Is it an expensive fix? Can I fix it myself?
It is fixable, It is the convergence circuit causing the problem. Unless you are familiar with electronics and with Projection TVs I would not attempt to fix it. Plus the way the convergence board is mounted with hidden screws makes it even more difficult. I would estimate cost would be around 300.00 to 350.00. The set is worth putting the money into it. I recommend a professional to do it.
Hope this helps,
Skyassoc
