SOURCE: m600I STUCK IN FLIGHT MODE AND I have hardly any power. In flight mode the batter will not charge.
Do you get the option to select Phone or Flight modes when you power the device on?
If not, you might want to try using the scroll wheel to do the following:
1. Open the Main Menu. (Scroll to it & then push the scroll wheel in to select.)
2. Open Control Panel, then Device, then Flight mode. ("Prompt me with the Phone on or Flight mode choice..." is displayed.)
3. If the checkbox is unmarked, select it.
4. Save.
5. Power off and then on. The choice should enable you to activate Phone mode.
I hope this helps.
SOURCE: sonny ericsson cell phone stuck in flight mode
some how you changed the proffile of your phone settings.. you can change it from phone settings or it was then wen you click the turnoff button once
SOURCE: MY PHONE WAS ON NORMAL MODE SETUP, I CHANGED TO FLIGHT MODE HOW C
if its sony ericsson, just restart it then select the normal mode.
SOURCE: my smadl phone has become
If you do not have your manuel handy or it does not have the information needed to re-set the mode, try asking an employee of almost any cell service provider; they are usually happy to help, as it makes their day go by more quickly, they are helping a potential future customer and they also have access to manuels for almost all cell phones (even if they need to jump online). Without having your phone in front of me, the only other thing I could suggest is to find the manufaturers web site, then find your phone model & check for instructions/manuel info direct.
There is also this; in your main menu, you should have a settings choice; follow it past bluetooth & security to the SETUP/OTHER or something that looks similar (ie, not display, sounds location, etc). This should be where he TTY & Airplane mode are; enter OK on that & follow the requests or directions, as this may lead you directly out & re-set you out of the Airplane mode.
Good luck, & have a wonderful, safe holiday season.
