How you speed up a fan on a rheem air handler to blow more air in my house
    President:
  • 2,976 Answers
You can change the size of the pulleys. Either increase the fan pulley size or lower the motor pulley size. Don't go more than 1 inch at a time. You will also have to change the length of the belt. The motor runs at 1725 rpm's.
Posted on Jul 03, 2009
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Is their a way to reset air handler fan?
check to see if the starting capacitor is good
My Rheem Air Handler runs all the time,a/c works fine and cools the house but I want the air handler to kick off when not in use. It's model RBHA-14J00NFRA Volts 208/240VAC PH/HZ 1/60
IS your thermostat set to automatic on the fan switch? If so then you may have a stuck fan relay in the air handler. If it has an electronic control board the relay is on the board and the whole board would need replaced. If it is not a stuck relay then you could have a crossed wire from the thermostat to the air handle, usually the green wire from the t-stat, it could be crossed with the red wire that supplies 24 volts to the t-stat.
Jun 17, 2011 | Heating & Cooling
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
How to adjust blowed speed on a rheem air handler
There are probably six wires coming out of your air handler blower motor. There are 2 brown wires which are capacitor wires, one white wire which is neutral, and probably red,black, and blue. Look behind the door of the air handler to see the wiring diagram. They should have the color coded speeds marked on the diagram. There is probably some sort of control board that the blower speed taps plug into. By changing these wires around on these taps you can adjust the speed of the blower motor.
Jun 05, 2010 | Heating & Cooling
Unit not blowing. There is ice build up on the line between unit and the house wall outside. What should I do.
If is not blowing ,the fan in the air handler is not working.It could be the capacitor or the fan motor itself, but if the fan works and you have ice in the air handler coil could be that the filter, is dirty, the coil is dirty or the unit is low in refrigerant.
Jul 30, 2009 | Heating & Cooling
Temp in my home will not drop below 81 degrees
Air Handlers differ in the way they adjust there variable speeds. Carrier you just plug into a pin. Trane has dip switches with directions on the fan housing. Before you try to adjust please kill power to air handler. Varriable speed are very sensative to voltage. If I new your air handler brand I could help. But just check the wiring diagram and they may ahve dirrections on there for setting speed. Need more help call back Rus
Jul 04, 2009 | Heating & Cooling
Air handler fan not working
Check the fan relay switch in the air handler.
Check the fan motor capacitor.
Check the fan blower wheel for binding.
May 25, 2009 | Heating & Cooling
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Heating & Cooling Logo
262 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
