Question about Gateway HD2200 LCD Monitor
Same problem 2 seconds on, then turns black
Monitor HD2200 flashes the Gateway logo upon startup, then goes black. Occasionally, it will display the login screen for maybe 2 seconds and then go black again. It is less than a year old. It does NOT power off, the power remains on . HAVE A SOLUTION?
  • 12 Answers
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Posted on Jul 28, 2009
I also had the same problem with the LCD powering up and then turning off. replaced all the caps, reflowed the whole power supply board, and tested voltages. turns out one of the CCFLs was bad. i temporarily swapped out the bad one with a laptop CCFL to test. lamps are reported to be 480mm X 2.6mm.
Posted on Jan 29, 2010
2 Suggested Answers
  • 127 Answers
SOURCE: monitor goes dark after a few seconds
change your cables, there might be a problem with them though you may not see until you use a new different one.
if the problem continues, it will be the monitor that has to be serviced.
i would like to hear from you,
thanks,
wonder
Posted on Sep 18, 2009
I figured out how to adjust the brightness on my Gateway hd2200 monitor but it won't brighten it flashes on bright for a second and then goes right back to dark is there anything I can do thank you
Jenny
In some monitors there is a HUD display, there you can reset the board, or program that control colors and other settings, also you can press if is available, a botton that automatic change colors, RGB, cinema, movies, games, etc.
Carl
Jul 17, 2016 | Gateway Computers & Internet
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
Monitor goes dark after a few seconds
it looks like the video driver needs to be chcked. can you try to go to the bios of your omputer by pressing f2 on boot and let it stay there for 5 minutes? if it still goes to a black screen, its either your video card or lcd thats having a problem. but if it doesnt goes to a black screen in bios, its just the video driver. go then to safe mode by pressing f8 on boot. then uninstall and reinstall the video driver. or run system restore. restore it back to a working date thts by clicking start, then click all programs, go to accessories, go to system tools, click system restore, choose an earlier date and hit next, follow the prompts,wait for the computer to restart and that should work!
Sep 18, 2009 | Gateway HD2200 LCD Monitor
Gateway FPD2185W
The next thing to try would be to resolder all of the connections on the transformers in your monitor. If you can take a few pictures of the board and email them to me I will mark the points to check and send it back to you.
Buddy
Corporate Computer
www.ccl-la.com
Aug 14, 2009 | Gateway HD2200 LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Gateway HD2200 LCD Monitor Logo
1,337 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
