I replaced the multi-switch, emergency flasher relay,bulbs. All fuses seem to be good. Not sure what to do next.
SOURCE: Tail lights/front parking lights don't work.
Please use this link:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800c4326
Good luck..
If I understand you right based on your post/description, the signal lights would still turn on even if any or both of the flasher relays are removed. Should this be the case, then the signal lights are not getting the power from the flasher relays but from the brake light circuit.
Perhaps your concern is not with any of the flasher, but simply missing or loose ground more particularly with the rear lights. Perhaps you could try determining which of the wires for the brake lights and signal lights (as they come out of the light assembly) would be ground . A test and even possibly a temporary workaround is to hard wire a second ground connection from the determined ground wire of the lights and attach it to any conveniently located bolt or screw to the body. it may be to your advantage to do this on all the rear lights assembly.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Emergency Flashers totally out, Rear lights malfunctioning
Check the ground on the passenger side rear lights, it's likely bad. As for the hazards, sounds like a bad flasher or fuse.
SOURCE: I have A 2000 Chevy 3500 Express Van and the brake
When you said that you checked the brake switch, did you check it live? Meaning verified live power to the switch, press switch, and then power came out the other terminal?
If so, also verify zero power on brake press, at the offending brake light bulb terminal. You must verify the test light each time you move it...leave running lights on...
After verifying that there is no power coming, after the brake is pressed, note the wire color and find it where it comes to the steering column and test there... This would eliminate wires and connections between front and the rear of the vehicle, unlikely, but needs to be tested.
After verifying no power at that terminal, then yes the t/s switch is certainly suspece. This may be the time to get a mechanic to verify and replace the switch, there are locks, tilt mechanisms, air bags, column bearings, etc involved. Failures risk loss of vehicle control (locking or binding for example.)..
Hope this gets you going in the right direction.
Testimonial: "Thank You. I tried those things and it seemed to be the Emergency Flasher switch in the multi function switch."
SOURCE: Turn signals not working.All bulbs are good,no
The emergency flasher and the turn signal flasher are two separate items. You could have a defective T/S flasher.
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light
Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep
Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR
4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
Thesedetails will help.
Thanks.
