Question about Haier hwr10xc6 Air Conditioner
Haier 8000 btu thru the wall ac wont come on
A brand new haier 8000 btu thru the wall ac came on once, but when i tried it for the second time, nothing happens. The reset button appears to work, the light is green, nothing happens when i push the on-off switch.
  • 6,927 Answers
Try ot unplug for 2 minutes,,, and try again may have fuses inside also
Posted on Jul 03, 2009
Is water supposed to leak out of the back
no only out of the drain check to see if it is clogged or does not have a p trap in it it should
Sep 14, 2014 | Haier CPRB08XCJ 8000 BTU Portable Air...
A brand new keystone thru-wall air conditioner is installed and plugged in. The power is on but it doesn't work. What could be the problem?
The unit has a start time delay (3 to 5 minutes) to protect the compressor against starting under high after a short time power failure. Most people tend to turn the unit off when it doesn't start when turned on.
Jul 28, 2014 | Keystone 12,000 BTU Thru-the-Wall Air...
With a Kenmore 8000 BTU ac window unit there is a green wire that runs from underneath the control panel. Where does that go?
Most of the time a green wire is a ground and should be attached to the metal frame using a existing screw or a self tapping sheet metal screw. Thank you.
Aug 26, 2011 | Kenmore 75080 Thru-Wall/Window Air...
How many BTU is Model#580.74085 580.74124
8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Jul 23, 2009 | Haier hwr10xc6 Air Conditioner
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
This Kenmore AC is probably dead
yep you would be better of getting a new one sounds like your compressor dead.
Feb 05, 2009 | Heating & Cooling
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
585 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
