Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
The unit will not release water.
The bladder is full of water and the unit seems to power up okay, but when I depress the trigger to release the water nothing happens.
  • 48 Answers
You do not state wich model it is , check to see if water comes out of the hose ,If water comes out of the hose the pump is working ,either the heater is clogged or the spray tips
Posted on Jul 19, 2009
    President:
  • 2,976 Answers
The water release probably has the hose pinched shut. Storing it with the trigger depressed will eliminate this. You'll have to find the spot, where the hose gets pinched, to shut off the flow and turn it 90°.
Posted on Jul 03, 2009
My Bissell wont spray water
Then check out the plumbing and mechanism responsible for the spraying of the water. Trace it out.
Aug 27, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
The cleaning solution does not dispense
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Aug 06, 2016 | Bissell 1698 PowerSteamer ProHeat Upright...
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Ava B.
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
No liquid through accessory hose
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Nov 08, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Won't spray water and cleaner from the machine
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 24, 2010 | Bissell 9200 Upright Vacuum
Why isnt my carpet cleaner releasing or putting any water out onto my carpet
I believe we own the same model or one that operates like it. If so, then yours has a "bladder" for the clean water, it has to be almost full sometimes before it will release any. Check the nozzle on the bottom of the tank body and on the cleaner for anything that might clog it up.
I think it will also release water only when you pull the cleaner toward you and hold the trigger down long enough as well...it does not release when moving forward.
Also check the bottom of the cleaner and clean off anything stuck to it...it gets pretty dirty and that is where the water comes through.
Dec 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Powersteamer Pro Deluxe
could be a few things.. take the lid off the tank and try spray.
did you fill the bladder and not the outer tank.. rubber on bottom of tank still there.. releases fluid it you depress the x shape center..
hot water. prime from hose without a tool on it by holding the hose lower than the tank.. put in on a work bench.. hold spray trigger and turn on machine.... read my other posts as well
Oct 23, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
544 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
