Question about Maytag Washing Machines
Washing machine will aggitate but will not drain
Will not drain
  • 784 Answers
The pump is control by the timer after a set event of agitation.Check the Timer first then check the pump itself.
Posted on Jul 03, 2009
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Washer fills with water but will not drain and the aggitator is not moving either. Could the problem be a bad or stuck aggitator?
When the machine is ready to drain get the hose in the back and put it down either out the window or in the tub what ever is closer and the water runs out on its own
Aug 06, 2011 | Washing Machines
MY WASHER AGGITATES BUT DOESNT DRAIN WATER OR SPIN OUT
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 10, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washing machine doesnt aggitate
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
the first thing to check is your lid switch.
does the unit drain or spin?
you may need to check your drain pump to see if anything is stopping it.
you should also check the wiring from the motor to the timer.
Mar 25, 2010 | GE WBSR3140DW Top Load Washer
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
