Question about Nokia 2610 Cellular Phone
Sim card not connected warning. Phone won't turn on, now.
Phone reads that the sim card was not connected. I took the battery out and the sim card out. I cleaned the sim card and replaced it and the battery. It worked for about 15 minutes then the "sim card not connected" warning showed again. I did what I did before; now the phone won't turn on.
My Sim Card won't read in my LG Gm310 phone
Perhaps the sim card was not initialized. Initialization allows you to communicate.
Feb 11, 2018 | LG Cell Phones
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
I have a Nokia 5800 Express Music, I tried restoring my phone to its factory settings and it froze for ages on a white screen with Nokia written on it in blue, I took the battery out, turned it on again,...
hey guy ptoblem is not in the sim or battery. it is the memory card who is the culprit.teke out memory card , back up data on computer ,format ihe memory card.
now copy the backed up data to memory card again .
switch on your phone now and then insert the memory card.
Everything is fine now.
For detailed explaition read this tip by clicking here
Sep 05, 2010 | Nokia N70 Cellular Phone
I dont know the puk code
  • Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  • Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  • Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  • See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  • Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
  • SIM cards come in different carrying capacities that may not work with all phones. Be sure to check with your provider to find out what size card your phone uses if you plan to purchase a SIM card from a source other than your cellular carrier.
  • Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself
Sep 25, 2009 | LG Vu CU920 Cellular Phone
Need PUK code, T-Mobile SIM is deactivated (cancel line)
  1. Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  2. Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  3. Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  4. See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  5. Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
Sep 24, 2009 | Nokia 8800 Cellular Phone
I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
Jul 23, 2009 | Samsung Cell Phones
SIM card is not being read.
Try to clean the SIM-card with a washcloth. Not too much water in it, just a little.
Jul 08, 2009 | Motorola Cell Phones
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Insert sim
Try rigorously cleaning the sim card and phone connections (also battery connections - after reading forums the batteries on V3's are often to blame for their problems) with a cotton bud then leave the phone off without the sim card in it and charge it overnight. Then put in the sim card and turn the phone on. This might help. My V3 often says Insert SIM and it is very annoying so i'm getting rid of it but those methods have worked for me.
Hope this helps
Mowcius
May 12, 2008 | Motorola Mobility RAZR V3
Emergency Download/LG
mine does too i took battery out then back in it worked but now it syas that again. charge it up
Feb 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Nokia 2610 Cellular Phone Logo
153 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
