Question about Kitchen Appliances - Others
Car Battery Charger - Repair
I have an Exide Car Battery Charger (Model 7067512). It stopped working, and I've narrowed the problem to a bad diode. The diode does not have any part numbers written on it. Exide was not able to help. Century Tools, which stocks car battery charger parts, could not find my model number and was not able to help. Can I use an alternator diode (stocked at Sears)? How can I determine the diode rating that I should look for (i.e., my Exide Charger has a 75/12/2 amps charging options, should I look for a 75 amps surge amp rating on a replacement diode?) Thanks.
  • 75 Answers
Thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Posted on Jul 03, 2009
Change exide fork lift battery charger from 240v tap to a 208v tap
Download the installation manual. It is too dangerous to explain the procedure on this site. You need a visual. Be careful and stay safe!
Feb 03, 2016 | Exide Computers & Internet
Manufacturing year of Exide MR700 so no A2G4D026543 2142
This doesn't sound like it relates to UPS systems. The Exide MR700 is a charging unit for rechargeable batteries.
http://nirbheybatteries.co.in/product.php?pid=622182
The Exide MR700L is a car battery.
What is it you are asking about?
Jun 05, 2015 | Exide Computers & Internet
2003 HONDA ELEMENT DIES WHILE DRIVING
Sounds like a bad connection somewhere. Maybe the thieves or the repair shop damaged/loosened something. I would start the car and start wiggling/moving wires and connections to try to narrow down where the problem is. Start at the alternator connections, both at the alternator and where the thick wire connects, probably at the power distribution box but it may go straight to the battery; don't recall on that car.
Apr 11, 2017 | Honda Element Cars & Trucks
Can a car battery be refilled
you need a battery charger,density measuring tool and a lot of patience.Ina functioning new battery electrolyte measurement should read 1250.The acid part of a non functioning battery gradually is absorbed by plates and produces leadsulphur.If elecrolyte level in the battery is ok,put your battery under A High Voltage Low current charge.Use a 40Wcondensant light bulb connect a 1ampere diode in seies with it connect the +ve terminal of diode to +ve side of bettery and connect -veside of battery and 40W lamp into your mains inlet(220V or 110V).Leave your battery under charge for 24 hours .If the light bulb starts emitting light leave battey under charge for a few more days and then continue charging with a high curent(2-5)ampers-low voltage charger for a few more days.Hope your battery is back to life.N.B.IN THE FIRST STAGES OF CHARGE LIVE AND DANGEROUS VOLAGE (220) IS PRESENT AT YOUR BATTERY TERMINALS .SO BE VERY CAREFUL.
Sep 14, 2012 | Exide /Powerware PW9120 BAT-1000 UPS...
It wont charge my phone
Please respond and clarify what model HTC phone you have and what happens when you try to charge it.
Also, what charger are you using? Is it the original charger? How about another charger. Do you have a car charger or another wall charger that you can try to use? Just try to narrow it down to a bad charger or if the phone is the problem. Also, if you can find another battery (at your local cell phone store), they should help testing the battery.
EJ Kudelka
Can you borrow someone's
Mar 13, 2012 | HTC Cell Phones
I WANT TO CHECK THE MAUFACTURING DATE OF EXIDE BATTERY MFG CODE 2 BO S.NO. 61610
2B0
2 stands for factory No.2 of Exide
B stands for FEB.month like A-Jan,B-Feb,C-March.....
0 year 2010, eg: 1: 2011,2 : 2012, 9: 2009
Dec 22, 2011 | Exide Chloride Power Station (EXP2000) UPS...
My dewalt drill charger started smoking when i put the battery in although it wasn't even pluged in to the wall and now won't work
If this is for the 14 and 18 volt batteries, this is what I found had occured on one model I repaired (I've forgotten the charger model number):
It had a shorted diode (the bad one had obvious burn marks on the pc
board). I used an NTE 5809 diode to replace the original one. BTW you'll need
a Tamperproof Torx T-10 to open the case to access the pc board.
Feb 10, 2010 | Dewalt Drills
What battery should be used in the car?
It depends on which brand of car battery you prefer. You will get a range of different opinions on which brands are the best based on experiences with different brands.
If you are happy with the Exide brand then the battery selection depends upon which engine you have fitted in the car - the 2.2 litre or 2.4 litre. Anyhow here are some Exide models that will fit your vehicle. You need an Exide 75 size/model with the correct minimum CCA (cold cranking amps)
2.4 Litre engine - Exide 75 - 600 cold cranking amps
2.2 litre engine - Exide 75 - 525 cold cranking amps
Any large battery retailer will be able to help you select a battery suitabe for your car but many specialise in particular brands. Personally I prefer to select a heavy duty battery that is suitable for the vehicle and will offer more than the minimum required cranking amps.
Dec 06, 2009 | 2000 Pontiac Sunfire
Kitchen Appliances - Others Logo
1,221 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
