Question about Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System
Why is my garage door base unit beeping, what could it be?
Why is my garage door opener beeping?
Hello, Debbie -
I hope you have the user manual for your garage door opener so you can check it to find out what the beeping sound means. If you don't have the manual, you can add the name of the garage door opener manufacturer to your question by using the Edit feature, so that I or someone else can look up information specific to that particular make of garage door opener.
Many instructions I have found for a variety of makes of garage door openers state that the beeping can mean the back up battery for the garage door opener needs replacing. See the information here:
https://www.garagedoorrepairco.com/garage-door-blog/garage-door-opener-beeping-replace-backup-battery
Dec 26, 2017 | Building Materials
Battery is bad. I removed it and garage door opener is still beeping. It is driving me crazy. Help
as long as garage door is powered(plugged into outlet), then with a removed battery backup or a bad backup battery, the unit will beep to alert you to the issue. replace the backup battery with a new/good one.
Jul 11, 2015 | Chamberlain 3/4-HP Whisper Drive Plus...
Where is the back up battery located on garage opener?
Garage Door Opener Unit is usually connected to main power supply. I don't know if it has any battery. Try changing the battery in your hand held unit.
Jun 30, 2013 | Sears Craftsman LiftMaster Chamberlain...
My chamberlan garage door opener keeps beeping
The only thing on a chamberlain garage door opener that can beep is the battery back up unit. It beeps if it is being used or if it has lost it's charge or if it has lost the power to be charged. There is also an led light that will give you information on the status up by the battery too. These will be in your manual to decipher. You can get a new battery at chamberlain.com Thanks BB
Aug 21, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
''Overhead Door'' Garage Door Opener 1/2 HP Model 939 Base Unit Mod
YOU MAY HAVE A BROKEN SPRING.
CHECK FOR A GAP IN THE SPRING ABOVE THE DOOR.
IF YOU DO HAVE A BROKEN SPRING CALL IN A PRO.
THIS IS NOT A DIY PROJECT.
Dec 14, 2009 | General Electric GE 13-438 Overhead Garage...
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor is beeping
More than likely the battery back up is being used or the battery back up unit has gone bad. There is nothing else on a garage door opener that can beep. Look in your book ti decipher the beeping and color of the led codes it is giving you. Thanks
Sep 25, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Beeping light coming from unit
Unplug the unit for two mins. and plug it back in. That should stop the blinking & beeping, but blinking & beeping mean a problem. What kind of operator do you have? Maybe I can help you troubleshoot the problem.
Oct 25, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Logo
67 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
