Question about Belkin (F5D7230-4) Router (587009)
F5d7230-4 router
F5d7230-4 my router will not work wirelessly, the internet works fine as long as my computer is wired to the router although as soon as i disconnect the cable from the computer, i lose my connection.
  • 13 Answers
SOURCE: wireless connection works and then disconnects itself
look for a program on the web called Net Stumbler
It should be here http://www.stumbler.net/
That will show the signal level from your router.
I have seen this before and it could be several different problems
1. Someone else on your channel
2. Burned out ant or output section in the router
3. Broken Ant wire in laptop
Hope this helps
Posted on Jan 02, 2008
SOURCE: Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Posted on Feb 26, 2009
  • 50 Answers
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
Posted on Sep 23, 2009
govinda123
  • 2263 Answers
SOURCE: I have a Model F6D4230-4 V3 Belkin wireless
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on May 28, 2010
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Suddenly no connectivity after months of service
change your internet connection, or may be the modem is faulty due to some reason
Jan 08, 2010 | Belkin F5D7234-4 Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
No internet signal from router
To isolate the concern, it would be better to test the non working computer to the modem. If it works, that means there is a problem with the router and if it isn't then it is a problem with the pc..
If the computer works fine on the modem, you can try the following to check if the router works fine:
1. The modem should be connected to the router's WAN/Internet port.
2. The computers should be hard wired to the router's numbered port
3. On the router's setup page, go to the Status tab and check if the Internet IP address and the DNS are populated. If not, that means the router is not functioning correctly.
4. Go to the wireless tab and make sure that the SSID is customized. Make sure that the wireless computer is connecting to the said SSID.
If those had been checked and it still does not work, you can try updating the firmware of the router, reset and reconfigure it.
However, if the computer does not work on the modem. You may need to have it checked.
Sep 05, 2008 | Linksys WRT300N Wireless Router
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless router
delete and retry to enter instalation cd hope work cheers
Jan 14, 2008 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
162 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
