Home | Rice Cookers and Steamers | Ddifference between Pre...
Problem for Presto Rice Cookers and Steamers
Generic problem for all Presto Rice Cookers and Ste...
Ddifference between Prest models 06000 and...
By john541 on Jul 03, 2009
1/ Can you tell me the difference between your Presto Kitchen Kettle Multi Cooker models 06000 and 06003. I understand the the model 06003 uses an electronic temperature contol? 2/ Does the removable temperature control show the actual temperature settings in degrees or just numbers which would indicate higher or lower cooking temperatures?
3/ Does you warranty cover the finish on the inside of the cooking pot (teflon pealing) ?
4/ Why is this device no longer sugested for use as a deep frier.
Thanks John
Solution #1
posted on Jul 27, 2009
Not Rated)
DEW59
Rank: Wiz
Rating: 92%, 8 votes
The difference between the two models is styling. Both use the same temperature contol. Temperature settings are in degrees. The warranty covers the non-stick surface, but misuse or abuse will void the warranty. Normal household use will not affect the surface.
Was this helpful?
Yes
No
Questions and Unsolved Problems for Rice Cookers and Steamers
Answer
where i can bye a non stick pot
Answer
I wanted to steam cabbage how long and how much water do I need to put in?
Answer
i have a 5-cup Wolfgang Puck rice cooker. when i press the lever down to cook rice, the red light... (More)
Answer
I have a continetal electric rice steamer and I want to cook basic rice I want to cook 2 cups of... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Presto Rice Cookers and...:
Top Rice Cooker and Ste... Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Rice Cooker and Ste... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
