1993 Saturn SC2 Logo
A
Anonymous Posted on Sep 08, 2014
What is the cost of repair on a head gasket for a 1993 saturn sc2
What is the cost of head gasket repair on a 1993 Saturn sc2 including possible water pump leaking
carlos falero
Level 3:
Genius:
  • Saturn Master 1,327 Answers
  • Posted on Sep 09, 2014
 carlos falero
Saturn Master
Level 3:
Genius:
Answers
1327
Questions
Helped
349197
Points
2968
5 Related Answers
Anonymous
  • 110 Answers
  • Posted on Nov 06, 2008
SOURCE: Water on Drivers side Saturn SC2
Is it antifreeeze from heater core or heater core hose leak?  Is the leak pure water, or maybe something else?
Put it in the garage again overnight with an old white towel in the drivers foot well, best if you can find a way to stretch it from drivers seat forwar to firewall and keep it off of floor mat.  Check it before you go to bed,  then in the morning if no leak found yet.  see if the color/location of the spot helps you identify the source.  I think the heater core is under the dash center.  Anti freeze is green/yellow or orange.
good luck
Anonymous
  • 76 Answers
  • Posted on Nov 08, 2008
SOURCE: replacing head on 97 Saturn SC2
basically there wanting to know if its a single or double cam your particular model is a double over head cam. casting number should be next to the intake. and slant cam
Anonymous
  • 73 Answers
  • Posted on Mar 31, 2009
SOURCE: 2001 saturn sc2 gets code 341&340 camshaft sensor
if you have high resistance in secondary ign. system (plug wires, ign.coil) this will cause this code to set. make sure you are using a high quality spark plug wire set. not from autozone!!! and denso non platinum tipped spark plugs. also use a diaelectric grease on plug wires to keep moisture out.
Anonymous
  • Posted on Oct 03, 2009
SOURCE: saturn ion fuel pump
Misnikie32 . .. I just had the same problem around the time you figured out your problem and I just got it fixed yesterday. For almost 3 weeks I had starting problems and I constantly smelled gas. The problem is a safety issue and the car needs to be recalled. The hose that is connected to the fuel pump is cracked. Since the hose is incorporated with the fuel pump, the entire mechanism needs to be changed. Look at spending about 700.00 . I informed saturn and told them my life was at danger. Please contact them on their website and goto your state's attorney general and launch a complaint, as well as the office of defective investigations and the NTSAB (google them). This needs to be brought to their attention and all owners of this car. I googled this and many other people are having this problem. Some are even on this forum. PLEASE DO THIS ! ! ! !
David Shaub
  • 2994 Answers
  • Posted on Oct 27, 2009
SOURCE: 2003 saturn vue 3.0 engine, replaced timing belt,
You could have a leaking water pump gasket. Did you put sealant on it when you replaced it? were ALL surfaces totally clean?
1993 Saturn SC2 will not crank, but tries to turn over?
You are saying the engine cranks but does not start, right ?
Does it sound like it has compression ? If not could be a broken timing belt.
Change water pump on 97 saturn sc2
is there a question here?
If you need step by step instructions:
try a haynes or chiltons repair manual at your local library or purcha$e one at your local parts store..
Best regards
Ck
2answers
My speedometer on my 1993 Saturn SC2 just stopped working. What could be wrong?
fuse,gauge itself or fuel tank sending unit.The sending unit cost $121.79 at www.rockauto.com., More than likely its the sending unit.
How do i remove and repair the odometer light on 2002 sc2 saturn
get a repair manual, they are cheap on ebay. follow the instructions.
1helpful
1993 1.9 saturn sc2 starting problems
Sounds like the the Bendix is bad in the starter, which pushes out the drive gear to engage the flywheel. You'll need to replace the Bendix or the starter. It's a bit tough to get to the starter, it is underneath the intake manifold.
How do you remove the shell from a 1993 saturn sc2
remove the door handle, lift it up and you will see little plastic pins you can pull or push out. take off the mirror, look underneath the interior cosmetic mirror panel and you will find the bolts holding it on. Get a star driver and take out ALL the star head bolts holding the exterior panel onto the door. Lift the panel up and out.
20helpful
3answers
WHAT IS THE COST OF REPAIR ON A HEAD GASKET FOR A 1997 SATURN SC? THANKS, JOE
1.9L SOHC - head gasket set which includes all gaskets needed to remove cylinder head with thermostat runs about $150.00. Head mechine ( check for cracks and milled ) $145.00. Labor time to remove and reinstall cylinder head 8.5 hrs X shops labor rate.
1.9L DOHC - head gasket set and thermostat runs about $210.00. Head mechine $175.00. Labor to remove and reinstall cylinder head 10.7 hrs X shop labor rate.
Labor times per Mitchell labor book, this is a guide all repair shops used.
2answers
I found oil in my water reservoir what happened its a 97 saturn sl 2
Check your radiator, your transmission cooler is built in you radiator and is leaking in your coolant.I hope this helps you?
Replacing head on 97 Saturn SC2
3helpful
3answers
Saturn
Open the hood if it says efiohc or single cam on the valve cover then it is a sc1 if it says dohc or twin cam than it is an sc2
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
