Question about Panasonic KV S2045C Path-Through Scanner
Panasonic kv-s2045c connected by scsi car
I can't seem to find a driver for my panasonic scanner.
    Problem Solver:
  • 16 Answers
Get the most up-to-date drivers straight from Panasonic!
Posted on Dec 02, 2008
  • 1,601 Answers
Only scans 1/2 back page in duplex scan.
%95 of the times its a technical faliure, Talk to the store you bought it from or call Panasonic customer support, you can not fix this by yourself. =)
Jun 08, 2007 | Panasonic KV S2045C Path-Through Scanner
Need wia driver for panasonic scanner
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot or you might need to download hope one of these will help
hope this helps
Jun 10, 2011 | Computers & Internet
Its broken
Be sure you have installed all the drivers and softwared needed. Power the scanner off, then download and install the following from this website:
  • STI device driver
  • TWAIN driver
  • ISIS driver
  • User Utility
After all have been installed, reboot your computer. Once booted, power on your scanner and allow Windows to locate and finish installing the drivers.
Jul 21, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Most often this is due to a dirty sensor or reflector. dust will often build up over time and cause poor sensor readings and thus a red error light. There are four paper sensor sets on this scanner. Cleaning each of the sensors with canned-air should resolve this issue.
  1. the small black rectangle that is set down inot the paper-feed tray - this is the paper sensor.
  2. whe you open the scanner (like you would to clear a paper jam), on the part of the scanner that swings open and just above the two white plastic rollers, you will see another small black rectangle that has two "eyes" - this is the wait sensor. the wait sensor meets up with a shiny reflector when the door is closed; this reflector is just behind the large rubber roller on the base of the scanner - it may also build a layer of dust and need to be cleaned.
  3. a little further down on the open door, below the wait sensor is the start sensor, and it's reflector is on the base of the scanner just below the second set of small rubber rollers.
  4. the ending sensor is a little harder to get to. if you look into the area where the paper exits the scanner, you will see two blck rubber rollers - between these rollers you will see a "notch" - at the bottom of the notch is the reflector and just above is the ending sensor. this is the most likely cause of your troubles and usually a few strong blasts from the canned air will take care of it. If the reflector is real dirty, you can take a cotton swab and a few drops of rubbing alcohol and work it around in that area.
This is one of the most common scanner-error questions I get! I hope my wording is clear and helps you resolve this problem!
Aug 22, 2008 | Panasonic KV S2045C Path-Through Scanner
Inconsistent tif file creation with Panasonic KV-s7065c
pleaz oil the scanning lamp drive unit and clean the lamp
Sep 20, 2007 | Panasonic KV-S7065C Flatbed Scanner
KV S2045C scanner
Wow, it's been so long since I posted this, I cannot remember! I am the tech person and just was relaying the problem as an EX exployee relayed it to me. What did my original message say? I BELIEVE it was 1/2 black, but no image/words on the other half. Just black and white, but again, I cannot remember. Does it make a difference?
Dec 05, 2006 | Panasonic KV S2045C Path-Through Scanner
Panasonic KV S2045C Path-Through Scanner Logo
236 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
