Question about Dryers
My tappan dryer needs new cellinoids
How do I access these? Do I have to take the front panel off? If yes, do I need to take the belt off, too and remove the drum?
    President:
  • 1,136 Answers
Hi, Most models do not require the tub to be removed. If there is no service door in the front panel, you will need to remove the front panel. If you need information on how to remove the front, get me a model # and I can look this up for you.
Vic
Posted on Jul 03, 2009
Replace a belt on indesit dryer
Hello.
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Thanks.
Nov 07, 2011 | Indesit W 123 Front Load Washer
Can you give me information on how to replace the belt in the dryer.
From back of dryer remove access door to disconnect belt from motor & tensioner.(remember how belt was placed on tensioner & motor pulley) You must remove dryer front panel ( look for 2 screws at bottom of front panel) Pull out from botton of front panel to remove, exposing drum end retainer brackets, remove brackets, allowing access to drum. Slide old belt off & new one on.
Feb 13, 2011 | Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Replacement of belt on dryer
Here's how to replace a belt on an GE Profile DPSE810EG4 electric dryer. There may be some minor variation for other electric GE dryers, but it shouldn't be too different. DO NOT USE THESE INSTRUCTIONS ON GAS DRYERS AS ADDITIONAL PRECAUTIONS MAY BE REQUIRED! For the electric DPSE810EG4, you will need a #2 Philips screwdriver, a flashlight, a new belt, and patience. You will also need something very close to the left front of the dryer against which you will lean the front panel. A chair, a washing machine, or a wall all work fine for this purpose.
1) UNPLUG THE DRYER FOR YOUR SAFETY.
2) Pull the dryer away from the wall and disconnect the ducting.
3) Remove the top four screws on the back panel. (These secure the control panel)
4) Open the dryer door and remove the two screws on the top of the door frame. (These secure the top panel.)
5) Pop up the front of the top panel and slide the top panel forward an inch.
6) Unlock control panel by sliding it to the right, then pull it up to detach it from the top panel.
7) Lift off the top panel and set it somewhere
8) Undo the two screws that hold the front panel.
9) Pull up a little on the front lip of the drum while hinging the front panel forwards. On the DPSE810EG4, you can set the drum down on the support member that is underneath it. (On other models you might need to put something under the drum for it to rest on.)
10) Lift the front panel off of the pins that secure its lower end, and then hinge it to the left (be careful not to yank the wires). Lean it up against something.
11) Open the access door on the back. (On the DPSE810EG4 the access door is the exaust duct itself; remove the screw that secures it and slide it out of the dryer.) Set your flashlight inside the dryer aimed so that you can see the motor and the tension pully.
12) Remove the old belt. If it's snapped in half you can just pull it out. Otherwise, reach in through the back access door with your left arm and pull it off the motor, then come around front, lift up the front of the drum a little and slide the belt off the drum.
13) Reach in through the back access door with a cloth and remove any grease blobs on back of the tension pulley axle. (This way you won't accidentally get grease on the belt during the difficult step which comes next!)
13) Install the new belt. Lift up the front of the drum a little and slide the new belt onto it (the side with the parallel grooves should be touching the drum). Reach into the back access door with your left arm. Grab the belt and pull it around the right side of the plastic tension pulley and then pull it down around the metal motor pulley. You're less likely to get your fingers stuck if you grasp the belt from the front. (The side of the belt without the parallel groves should be in contact with the tension pulley. The side of the belt with the parallel grooves should be in contact with the motor pulley.)
14) Replace the front panel. Set it down on the pins, then hinge it forward while pulling up on the front lip of the drum. Secure the two screws.
15) Make sure the drum turns OK. (If it's fairly difficult to turn, you may wish to try removing the front panel and then try putting it back so that the drum sits inside the felt strip semicircle rather than compressing it. A drum that doesn't turn well will stress the motor and cause it to pause mid-cycle.)
16) Replace the top panel. Put it on top of the dryer, insert the control panel tabs into it, and lock them by sliding the control panel to the left. Slide the top panel back and pop it down in the front. Secure the front with the two long screws and secure the control panel with the four short screws.
17) Replace the rear access door / exhaust duct. Double check that you didn't leave anything inside (including your flashlight). Slide the exhaust duct back into the dryer and secure the screw that holds it.
18) Re-attach the rest of the ducting and move the dryer back into position.
19) Plug it in and make sure it works.
Dec 21, 2009 | GE Profile Harmony DPGT750EC Electric...
How do I access the belt on my Kenmore model
You have to get behind the dryer and remove the back. This will give you access to basically everything.
Nov 14, 2009 | Kenmore Dryers
Do I enter through the front panel or back panel of the the Maytag MDGT236AWW to replace the dryer belt?
yes you need to access either frt or rear covers to remove the top so you can put repl. belt around drum
Sep 15, 2009 | Dryers
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
