Question about Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM
Ev201nxm door doesn't seal/ices up
Our ev201nxm is 3 and a half years old. we have problems with it only in the summer when we turn our swamp cooler on.(we live in the desert) the door doesn't seem to shut and the vacuum doesn't work, so the freezer starts to ice up. this happens every summer, as fall comes and we use the swamp cooler less, and after defrosting, the freezer works fine and the vacuum seals the door. why?  i've defrosted in the summer and it ices right back up/door doesn't seal.
  • kkmagnet Jul 07, 2009
    this is a freezer only, and the door lines up perfectly. it is only three years old, and like i said, we only have a problem in the summer when the swamp cooler runs.?? it works perfectly 3/4 of the year.
  • 3 Answers
I have a EVL201NXRQ05 upright whirlpool. It was purchased in Nov 2008 in the Summer of 2009 the gasket was leaking at the top of the door. The gasket on this door snaps into place (no hardware needed). The problem is the door was bowed in the middle pulling the gasket down and away from the metal frame of the freezer - to the point the magnets in the gasket would not touch in the middle of the opening. I requested a new door while under warrantry. The door did not appear to be repairable it is a glued/foamed-inplace assembly. The new door looked straight when I installed it last summer and now it is bowed but not yet leaking. Whirlpool has a design / manufacture problem with this door design. I have received an extended warranty option from Whirlpool this past week 4 months after the factory warranty has expired. I suspect they know they have any issue, but not much is written about it. I may end up buying the extended warranty, but first I'm going to where I bought it to complain.
Posted on Mar 18, 2010
  • 4,070 Answers
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The gasket should be tight enough to securely hold a dollar bill all the way around.
Posted on Jul 03, 2009
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
I have ice building up under the basket. It is
I would check your door seals to make sure they are doing there job. If warm moist air gets into an area of cold this will happen. You may need to get new seals for your freezer door.
Oct 07, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I'm getting ice build up at the top of my Amana upright freeze.
This means the seal at the top is not tight and air is leaking in.
There are 3 possible fixes:
1. Loosen and Rehang the door so that a piece of cash-register receipt paper cannot easily be pulled thru the seal when the door is closed (all the way around) get someone to help. Dont take the door hinge screws out, just loosen them, push the door in to compress seal and tighten them again
2. Replace the seal ($12-30.00) - Take make, model and serial number of the appliance with you to eliminate a return trip.
3/ Treat with Armor All to make gasket seal soft again (2-3x) and give it a wipe all the way around with Vaseline.
Mar 26, 2009 | Freezers
Our 19.6 cf whirlpool "commercial" freezer (sn EV201NXMQ0312 building up ice in the bottom under the slide out basket. It actually builds up enough in a month or so to keep the basket from sliding out....
the ice build up is from a frozen drain line. you will need to remove teh rear cover in the freezer and you will uncover a coil at the bottom center there is a drain hole that allows defrost water to drain out. defrost any ice then flush the line out with warm water. if it doesnt clear right away you may need to use a large syringe or possibly a turkey baster to force warm water into drain.
BTW the door not sealing is not related to this problem. good luck peyton
Jan 27, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Frost free freezer leaking water everyday. the door and seals are fine. only 3 years old. ice appears in lower compartment.
When the freezer defrosts the water has to go somewhere. The defrost drain is stopped up. Blow it out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 26, 2009 | Freezers
No longer freezes
The evaporator fan in the back of the freezer blows over the cooling coils. Those coils are typically hidden from view behind a panel.
The problem you describe would lead me to suspect that the coils are iced over. That is why there is some cold, but not enough. The fan is blowing over a block of ice. An overfilled freezer is another possibility.
Iced over coils may be the result of a malfunctioning defrost system, a plugged drain tube, a poor seal on the door seals to the cabinet resulting in a lot of moist air entering the freezer (or fridge) or the refrigerant level is under pressure (needs more refrigerant added).
Most refrigerators never need refrigerant added, but after 25 years, it could be that yours does. However, it can only be done by a pro, and it probably isn't worth investing that kind of money in such an old fridge.
I recommend you start by unplugging the fridge and inspecting the coils inside the freezer. If they aren't iced over, then the door seals may be still be the problem by letting in warm air.
Jan 19, 2009 | Avanti Freezer CF62
Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM Logo
284 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
