Question about Sony Televison & Video
TV image blionks off and on
Our 9-year old SONY KV-20FV10 blinks off (black screen) and on perhaps a dozen times before anormal image appears. The blinking is growing worse (faster and longer episodesof blinking) as time passes. I tested the connections at the back of the TV;everything seemed to be fine. Any ideas?
  • 10,594 Answers
Your TV needs Screen Volt (G2) adjustment and you can do it yourself if you are comfortable with TV repair.
All you need to do is unplug TV from AC wall socket, take off back cover and find Fly Back Transformer 9it has thick wire that goes to top side of picture tube) This part has 2 control knobs on it.
Plug back TV in AC socket, turn TV ON and wait 10 minutes to get it warm up, turn slightly lower control knob clockwise to increase screen volts. Confirm picture appears on screen. Put back cover on TV and job is done.
Hope that will solve your problem.
If you need schematics of KV-20FV10, click HERE and HERE to download it.
Let me know further query, if any.
Thanks.
Posted on Jul 03, 2009
  • Shahid Electronics
    Shahid Electronics Jul 03, 2009
    Above info provided from service manual as shown in below image..
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony KV-20FV10 10 yrs old flat crt was working well but suddenly after 5 mins of play the screen becomes blue with horizontal lines but sound is ok
It sounds that the voltages to video output section has lost.
Visit the site named 'Electro-help' for more details. Click this link
View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 850 posts to different brand TVs now.
Sep 25, 2012 | Sony KV-20FV10 20" TV
My SONY Trinatron is starting to "blink", i.e., quickly pulse to a black screen. Each blink is about a second in duration. These episodes seem to vary from two or three blinks to as many as dozen. It has...
that is a capcitor near protection relay or a regulator
for 135 volt call str or the horizontal driver out put for the highvoltage. watcht theres is very high voltage in there.disconnect for a while before opennig the case IF YOU DONT HAVE EXPERIENCE CALL A TECHNICIEN !!!! and for me the price to fix it is about an hour time plus parts
hope that will help
regards. Alan
May 13, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Bad solder contacts on connector/component pins, oxydized connectors, dried up, inflated or blown electrolytic filter capacitors, burnt resistors.
Could be in the main or high voltage power supply, video section power supply, possibly in any of the other sections.
(these are just some ideas)
regards
3rq8 (Triarcuate)
Jul 27, 2009 | Sony KV-20FV10 20" TV
Sony trinitron kv-24fv10, image blinking
check the line transistor near the transformer ahaving a long cable going to a tube
Mar 13, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
3 year old VEGA TV: LED indicator 9 times blinking
Use remote control:
display, 5, volume +, power
I can turn on my TV, though with the fault codes on-screen. Holp it helps.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Mar 16, 2008 | Sony KP-46S25 TV
Picture doesn't come on
Is your screen black? If so then you may have a bad picture tube. I've seen this problem several times with SONYS. The thing seems to just open up and quit working.
Jan 09, 2007 | Sony KV-27S42 27" TV
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
