Sir help me: im not able to open my excel files directly,i need to open of one sheet of excel before i open the files,please help me in my case... thanks and more power!!
    Scholar:
  • 84 Answers
There might be a problem with you file association for '.xls'.
You can check this from Windows Explorer, on the menu bar choose Tools >> Folder Options... >> then select the 'File Types' tab.
Look to see if Excel is the default program to open the '.xls' file. At the bottom portion of the window, it shows 'Details for...' and 'Opens with'. Just associate it with Excel.
**Note: This may not be possible if you are NOT the administrator of your PC system.
Hope this helps.
Posted on Jul 03, 2009
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How to connect tally with excel file? sir/madam i want to connect my tally erp 9 with my stock (excel file) i maintain the inventory in tally, when i make a bill on tally on that time it automatically...
hi
deepu
in tally 9 ERP has a oprtion to export any date from tally to excel just open that page which u want to open in excel
then see on the top in tally page there is option for export file just folwothat u will able to export dot in to excel
Jun 26, 2010 | Peachtree Software Peachtree Complete...
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
Mar 24, 2009 | Microsoft Excel for PC
Tools protect workbook& sheet
Open the protected sheet... Go to edit and click select all. Go back to edit and click on copy. Open a new excel sheet, go to edit and click on paste. Now you have the copy of the protected sheet without the protection.
Jan 23, 2009 | Steinberg Cubase Studio 4 Upgrade Version...
Weird Excel problem creates oversized files
You have already find the solution by copying its contents to some other file. There can be a possibility that some virus has attached itself to the said file. Use a good anti virus and update is regularly.Another possibility is that you might have many of the rows or colums which you may have not noticed.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 14, 2009 | Microsoft Excel for PC
Problem in ms excel
right click on the file and click on properties, then uncheck the "read only" box. you need to also check if you have the admin rights to open the file since it could be the cause why you're getting that error. if it will still not allow you to open it, ask the author of the file to provide you the rights.
hope this'll help you and just ask me if you'll have other concern.
ciao!
Jul 10, 2008 | Microsoft Computers & Internet
Excel files do not opening autometically
reainstall it or repair your office from add remove menu in control panel or update online office updater microsoft ok cheak to see if u have sum download the latest flash and adobe shockwave and java ok
Jan 24, 2008 | Computers & Internet
Microsoft excel file dose not open autometically
hi Friends
here is the solution ifi Excel opens without opening any file after double clicking on the excel file,
1. Tools>Options>General uncheck "Ignore other Applications"
2. Exit Excel and try again
If this doesn't work try to re-register Excel
1. Close Excel first and On the Windows Taskbar
2. Start>Run "excel.exe /unregserver"(no quotes)>OK.
3. Start>Run "excel.exe /regserver"(no quotes)>OK.
See the space between exe and /regserver
if there is anyother issue in which may i help u then feel free to contact me
kamal_lalwani@dell.com
kamal0806us@yahoo.com
+9742128873 /
Jan 23, 2008 | Microsoft Excel for PC
Forgot password
Try this link http://www.download.com/Free-Word-Excel-Password-Wizard/3000-2092_4-10249516.html?tag=lst-0-1 It should help you unlock the Excel file and break the password. Good luck
Sep 02, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
